Old 02-26-2005, 10:23 AM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
Different shafts for a 10 bolt rear end?
Went to order a new axle shaft for a 92 K1500 Silverado, four wheel drive and everything was going good, got the axle and went to replace it, we got the old one out and put the new one in, and hell if it's the wrong one. We measured and the one that we had taken out of the truck is 1.25" diameter on the end of the shaft where the splines are at, but the one they gave us is only 1", so it just rotates in there and you can here the teeth grind on each other. Called them back and they said that there is only one axle shaft option for the 10 bolt, the only other one they have is for a 14 bolt. Is there anything else i need to know, because we recently replaced brake cylinders and they had asked us whether it was a heavy duty axle or not.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 02-27-2005, 09:10 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Different shafts for a 10 bolt rear end?
I'm pretty sure there are different size 10-bolt axles. The number of bolts should be counted on the RING GEAR, not on the cover. Almost all covers have the same number of bolts as the ring gear, but just to be safe, always count the ring gear bolts.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-28-2005, 01:32 AM
MadMac56's Avatar
MadMac56 MadMac56 is offline
Also count the splines...there are 28 spline & 30 spline 10 bolt rears
It's difficult to soar with eagles...When you're surrounded by turkeys!
Old 02-28-2005, 08:20 AM
mbumgua's Avatar
mbumgua mbumgua is offline
Four-wheel drive axles are 1.25 in.-- two-wheel drive 10-bolt axles are smaller--they sent you a two-wheel drive axle!
