Old 02-26-2005, 12:49 AM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
342 miles on 1 tank.
I just did 342 miles on 1 tank of el cheapo Arco Gas.......
Not bad for 3.55's and that was on the light.(Gas light for you pin heads)
That breaks my previous record of 327miles per tank.
My ride at my site Silverstangs.
Old 02-26-2005, 02:20 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: 342 miles on 1 tank.
What engine do you have? Either way, that is pretty darn good! 15 gallon tank?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 02-26-2005, 10:55 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Damn, I'm jelious! I'd love to break 200 miles to a tank.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-26-2005, 11:29 AM
Re: Re: 342 miles on 1 tank.
That was my gas guzzling V8 with the stock 15.75 gallon tank.
I put in 14.455 gallons when I refilled. I filled up before I went on my trip.
So that's about 23~24 miles per gallon on the freeway. Not bad for 2003 Mustang GT.
Old 02-26-2005, 02:05 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Re: Re: 342 miles on 1 tank.
anybody who says Mustangs get bad gas milage doesn know what the HELL they're talking about.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-26-2005, 02:20 PM
SkylineUSA's Avatar
Re: Re: Re: Re: 342 miles on 1 tank.
I have had over 20mpg in my 5.0, but then again I have had less that 10mpg as well
Old 02-27-2005, 05:14 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Yeah, mine's pretty throttle-input dependent. I saw over 350 miles on a tank when it was near stock (nothin' but exhaust and a K&N), but can see as little as 150 miles to a tank....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 03-01-2005, 12:57 AM
99onI95's Avatar
99onI95 99onI95 is offline
thats good for a v6. All highway and interstate?
2010 ALCAN 5000 driver
I own or have owned:
98 Ram Air firebird-WS6 hood and rear decklid, WS6/C5 vette rims, etc.
03 SRT 4-3'' exhaust, short throw, injectors, matte black
E36 convertible BMW-05 17'' BMW wheels
02 Volvo S60 AWD turbo-Stock
00 Audi A6 4.2L V8 Quattro-Potenzas, straight pipes
03 C240 Benz 4matic-stock
04 2.5rs Impreza
05 Chrysler 300C HEMI
04 GSXR-Power commander, K&N, gears, crash cage, suspension, LED tail
Old 03-01-2005, 01:43 AM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
He said it was a V8?
Old 03-01-2005, 01:50 AM
No, that's for my 2003 Mustang GT with the 4.6L V8 and 3:55 gears installed, and that was all interstate and highway.
Old 03-01-2005, 01:54 AM
I normally hit about 320 miles per tank with 90% freeway.
As far as being stock.......
I have
03 Cobra IRS with 3:55's
Griggs Racing coil overs
Spec Billit Aluminum Flywheel
SPec Stage 3 Clutch with the lightened pressure plate
Accufab throttle body and upper plenum
Magnapack 03 Cobra Catback Exhaust.
and several other things.
Old 03-01-2005, 02:17 AM
dampachi's Avatar
Banned
Ahh, why an IRS swap? Most cobra guys end up swapping for a solid axle.
Old 03-01-2005, 08:41 AM
Because his car is obviously not built for Quarter mile, it's a corner carver. A quarter miler would not use the aluminum flywheel or the lightened pressure plate either, we need the extra weight too keep from bogging on slicks...
Mine went down the most with the addition of 30 lb'ers and the cam, but I'm hoping to smooth some of that out with my TwEECer.
Freedom Isn't Free.
Old 03-01-2005, 01:17 PM
As SVTcobra306 said, my car is not built for the quater mile. I perfer corner carving, so everything that I am doing is based on getting my car thru the corners faster. The other benifit, is that the ride is alot better over all because with the IRS, I don't have the back end of my car bouncing around with every little imperfection on the road. The only way to solve that with the 8.8inch is to go with a Torque arm and a Panhardbar or Watts link setup.
The IRS is also about 44lbs heavier than the 8.8inch. But your getting Cobra R rear brakes. I also swapped to coil overs which also dumped alot of weight from the IRS, mostly because them springs are pretty heavy. I also installed the Motive Gear AX 3:55's which was 1.7lbs lighter than the Ford Racing 3:55's. My next step is to install the The Level 5 IRS Fix upgrade from The Drive Shaft Shop. It will allow the IRS to handle 900hp with slicks, not that I will use slicks. Then will come the Kenny Brown upper and lower control arms.
Hopefully with those changes, my rear end will be complete. So I will basically just have the chassis and engine to worry about.
Old 03-01-2005, 01:55 PM
dampachi's Avatar
Banned
Oops, I totally ignored the other mods. I just saw IRS and was like wow. It's cool..I wasn't trying to hate on you or anything. It's good to see some mustangs actually making turns. But eh, I myself love going straight. So to each their own! Good luck!
