Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 02-26-2005, 12:13 AM
asalcido asalcido is offline
rear brake drum removal
does anyone know how to pull off the rear brake drums? are they just pulled off or do you need a special tool?
Old 02-26-2005, 05:24 AM
Flash75 Flash75 is offline
AF - Advisor
Re: rear brake drum removal
I assume you have a Tocoma. They should come off after removing the wheel. You may need to to tap the outside of the drum with a soft hammer to break drum loose from the the studs. If there is lots of drum wear you may need to remove the rubber plug in the back plate and use a pair of screwdrivers to back off the automatic adjuster.
Clifton
Old 02-26-2005, 12:22 PM
bearcat329 bearcat329 is offline
Lightbulb
needed to check mine, there's 2 threaded bolt holes in the drum, if you can't get the drum off easily, then thread 2 3-5 inch long metric bolts into the holes and screw them in, this push's the drum away from the hub, take a few turns on each side, back and forth, until the drum's free.
hth
Rick, Ore
Old 02-26-2005, 12:35 PM
hth
Rick, Ore
Thanks for your help!
Old 02-27-2005, 12:14 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
As Flash said, back off the adjuster star wheel before you decide you need to pull off the drum with the bolts. It may be a ridge in the drum you are fighting and not rust.
