Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-25-2005, 11:39 PM
vanman74 vanman74 is offline
Correct OHM'S for CPS
I have two crankshaft sensors, one is new and one is suspect bad.
Suspect sensor has a resistance reading of 4.7M Ohm's center pin to outer pin.
New sensor has a reading of 3.7k ohm's on the same two pin's.
Suspect sensor is more magnetic than new sensor.(used a wrench to compare magnetic strength between the two. ((on work bench))
With new sensor installed jeep will barely run, but seems like it is way out of time. And than dies.
It's a 94' Grand Cherokee 4.0 any help would be great.
Old 02-26-2005, 04:35 AM
Cam7 Cam7 is offline
The manual says check resistance between terminals B & C. B is center and C is toward the passenger side. There should be no resistance it says to replace if it has low resistance.
I have a new one will check resistance and post back.
Old 02-26-2005, 06:20 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Correct OHM'S for CPS
venman74 - was the new CPS BORG WARNER brand?
venman74 - was the new CPS, BORG WARNER brand?
Old 02-26-2005, 07:36 AM
The brand I bought is niehoff (AL2019). The original brand is unknown.
Old 02-26-2005, 08:00 AM
Oh yeah, forgot to mention, I was doing some voltage checks on the sensors w/key in on position, and forgot about it. I went to work, the next day and when I came home I could here the alarm barely working. The battrey had drained so low the dome lights wouldn't even come on. I completely disconnected the battery but the alarm still continued to make noise(my neighbor said she heard it when she walked by and thought it my be a squirell) So, I had to jump start it, and a couple of times
