Go Back   Automotive Forums Car Chat > Geo > Storm
Old 02-25-2005, 11:27 PM
gheilmann2001 gheilmann2001 is offline
Unhappy 1993 geo storm 1.6 clutch ?
I replaced the clutch and it worked fine for a day and then shifted gears and it there was no clutch(it was like it was in neutral) took it apart and it looked fine. I noticed that the flywheel bolts had rub marks on them and the pilot bushing( a plastic bushing) had a smaller hole in it then the transmission mainshaft. Is there another bearing that goes infront of the plastic bushing or does the enf of the transmission mainshft not go into the bushing? pls help.
Old 02-27-2005, 10:27 PM
STORM20i STORM20i is offline
Re: 1993 geo storm 1.6 clutch ?
did you check if there is a clutch master Cylinder if there is check the fluid and check for fluid leaks. Check the lines and every thing like the linkage too.
Old 04-06-2005, 03:27 AM
grindingears grindingears is offline
Re: Re: 1993 geo storm 1.6 clutch ?
check to make sure you didnt install it backwards
