Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-25-2005, 11:19 PM
shaddoe shaddoe is offline
finally finished the red roadster, back to my z project
http://www.exoticglass1.com/johnscott.htm ,the numbers are links for videos
i can finally start working on my car again. i got the passanger seat out and using it for a pattern to make my new leather seat covers. still waiting for my doors but i did finally sand a prime my back hatch. i have a full set of corvette c5 brakes(rotors and calipers) and am thinking about using them on my z, it should be pretty easy to make new brackets to hold the calipers. i'm also planning on pulling the new fan off and getting an electric fan, i noticed a big difference from when i first drove it without the fan and then when i put it on. i have a lot of other things going on but thats probably the biggest of the projects.
Old 02-25-2005, 11:26 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Thats a pretty good replica. Most kit cars look really bad.
Anyway, machining an adaptor for the C5 brakes would be easy enough, I don't know how easy it will be to make up a custom fitting for the brake line though.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 02-25-2005, 11:28 PM
Zgringo Zgringo is offline
People keep thinking i'm shitting them when I tell them to put on a electric fan and water pump. It'll make about 30+HP.
By the way...that mid engine car is super...looks good.
Old 02-25-2005, 11:42 PM
i know what ya mean. i found the biggest gain from not having the fan of all the other things i did.
Old 02-25-2005, 11:44 PM
Re: finally finished the red roadster, back to my z project
i think that will be pretty easy. i have a set of steel braided lines and will only have to get the ends to attach and the calipers and the blocks.
Old 02-25-2005, 11:50 PM
Either that or make an adaptor to go from the steel lines the calipers or body as needed. But, the fewer connections the better. Anyway, it will be a hell of alot cheaper than buying an upgrade kit.
Where'd you get the panels for the Lambo? You make the frame up yourself or was it built to a set of specs someone had come up with?
Old 02-26-2005, 12:01 AM
i purchase the fiberglass body from a company in pennsylvania, i build everything myself, also do the painting and upholstry myself. you can see others i built at www.exoticglass1.com
the brake kits i use on these cars is 13" all around and runs $2900 for everything which is much cheaper than the ones i've seen for my z.
Old 02-26-2005, 02:02 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
sweet ass replica dude, i'd drive that any day lol... i love the hesitation into 5th in the shifting video... go over to the 3rd set... umm.. umm umm, which way's it supposed to go... oh yeah down *shift* lol.. are all mid engine cars like that?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 02-26-2005, 02:06 AM
Re: Re: finally finished the red roadster, back to my z project
actually lamborghini is backwards like that, i usually set it up for the standard pattern but the customer wanted like that. it messed with me bad when down shifting.
Old 02-26-2005, 02:21 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
i must agree, that is a very nicely done replica. major kudos!!! now get that Z32 going because i want to see the finished product.
ZedEx Crew Member #4
Old 02-27-2005, 11:46 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
that is a awesome replica
Old 03-01-2005, 10:06 PM
I keep telling them that lots of HP can be made real cheap.
