Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-25-2005, 08:09 PM
David Sigman David Sigman is offline
Send a message via AIM to David Sigman
HELP! my contour won't start
ok I'm usually pretty good at figuring stuff like this out but I'm lost.
I have a 96 contour with the 2.0L 4 in it
I have fuel at the rail and power to the coil, but it won't start so I went ahead and did cam and crank sensors and a new coil cuase the cars got about 100k and it wouldn't hurt to do a little maintenance. well none of those help so I get out my meter and my manual and start poking around around. I have 1.5V for the crank sensor at the bulkhead connector and the sensor same thing for the cam sensor so I know the harness is ok...
it sounds to me like my pcm is probably bad but before I go and spend a ton of money I just want to make sure I'm not over looking something...
I've inspected and cleaned all the grounds. it just started doing this for no apparent reason.... I don't even have any codes...
appreciate any input that anyone might have
thanks
Old 02-26-2005, 07:53 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
hmm...thats a tough one. I doubt the ecu is the culprit, but i guess anything is possible. Try disconnecting the MAF and see if it starts and runs on limp mode.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-31-2005, 01:54 AM
tagra123 tagra123 is offline
Re: HELP! my contour won't start
thanks
ECU usually will not cause a "No Spark" condition.
Check the wires to the ignition module. If they are making good connections then try replacing the Ignition Module.
