Old 02-25-2005, 07:14 PM
poordudewhowantcar poordudewhowantcar is offline
Send a message via ICQ to poordudewhowantcar Send a message via AIM to poordudewhowantcar Send a message via Yahoo to poordudewhowantcar
My speedometer wont work ?
what could be the cause of this and how can i fix it ?
the temp and gas work. but the miles per hour needle does not move . ?
Old 02-25-2005, 07:52 PM
Scott82 Scott82 is offline
Re: My speedometer wont work ?
Speedometer cable possibly
Old 02-25-2005, 08:23 PM
Hybrid1990crx's Avatar
pull the speedo cable from the trans, pull on the inner cable, if it pulls out of the housing then you found your problem.
Old 02-26-2005, 12:14 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
yep replace speedo cable, it almost always solves the problem. After 15 years it tends to wear out. When i replaced mine it worked like new
; p
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-26-2005, 01:29 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
well, check to see if the speedo cable has pulled out of either your gauge cluster (top pic) or your transmission (bottom pic). then it wont cost you a thing to fix it
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-26-2005, 05:55 PM
well i just recently pulled my dash out and every thing seems fine to me.... So exactly how do i find the speedo cable on the trans?!
Old 02-26-2005, 06:32 PM
its down in the back of the motor on the tranny, there is a wire that comes from the firewall and travels to the tranny, if you look im sure you'll be able to find it.
Old 02-27-2005, 02:27 PM
i checked the fire wall and a vacum comes out to the TB. and two wires run to the ?DIZZY??? i cant find the speedo cable any one have pics? ill try to post up pics of all my Fu<kin probs. soon as i find my camera
Old 02-27-2005, 03:02 PM
I meant to attach these two pictures to my original post...
ZC stuff
Old 02-27-2005, 09:45 PM
skotman's Avatar
skotman skotman is offline
mine did that. the cable just came unplugged in the engine bay where it connects to the transmission or whatever. i just plugged it back in and went along my merry way.
Old 02-28-2005, 10:46 AM
Canabalooza Canabalooza is offline
Mine wasnt working and it was still plugged in problem was that the little thing at the end of the cable wasnt aligned right so it didnt go all the way in. it goes in about an inch to and inch and a half if i remember right. if its plugged in and it doesent work try moving the plastic end and putting it back in. does yours even have the end in tact or did it break off?
Old 02-28-2005, 12:36 PM
well mine is plugged in and it has the plastic piece surrounding it ill try to work with it
Old 02-28-2005, 12:38 PM
is there a little plastic end coming out of the cable? its kinda like a little square or sonething i think. it turns when you move it. if you turn it have someone look at your speedo when you do it, do it light and if your speedo needle works then its just not plugged in far enough. if you push on it and it clicks keep pushing and it should click a second time. least thats what mine did.
Old 02-28-2005, 12:43 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Any time I have to reach around between the firewall and the motor, I end up dislocating the speedometer cable, mostly because there's a little clip that's supposed to hold it to the transmission, and my car is missing that clip.
When I work on something and the speedo stops, I just drive and see if it works. If it doesn't, I pull over and jiggle it. I drive again. Repeat. Sometimes it takes 6 tries.
It has always worked.
Flunky
Old 02-28-2005, 12:44 PM
well last night i only checked ot see which cable the ODO is now that i know ill try to fix my prob.... id did how ever pushed it closer to the tranny but i didnt here or see a difference.
