Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 02-25-2005, 07:10 PM
Myke87Si Myke87Si is offline
Send a message via AIM to Myke87Si Send a message via Yahoo to Myke87Si
87Si idel way to high
i've recently replaced the head gaskit in my 87 crx Si and i can not control the idel. its running at about 5k. and nothing i do will bring it down. clamping vacume hoses and so on. i am going crazy with this thing. thanks
Old 02-25-2005, 10:17 PM
aquarius's Avatar
aquarius aquarius is offline
Re: 87Si idel way to high
My bro had the same prob and I am sure he will help you out as soon as he can. oh yeah and welcome
Wheels spin tires burn. Racing!!!!
Old 02-27-2005, 10:36 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
If you've already tried the idle adjustment screw then it has to be a vacuum leak.
Also, there is one hose that is connected directly under the intake manifold plenum that is extremely hard to attach and incredibly easy to forget.
Is the ECU displaying a code?
Old 02-28-2005, 03:09 AM
matt s matt s is offline
Another thing to think of is to replace the gasket or whatever its called that houses the idle adjustment screw because the spring will wear and when the little cone inside goes to compress against the spring for a nice seat, the spring could be giving when it does this causing either higher idle or idle seek causing in high idle...
