Old 02-25-2005, 05:55 PM
lmorgan lmorgan is offline
Send a message via AIM to lmorgan Send a message via Yahoo to lmorgan
87 honda accord speaker wiring diagram
Hi,
Anyone know the colors for the speaker wires for a 1987 Honda Accord Sedan? Or know where I could find out? Also need to know ignition, hot, antenna, etc.
Thanks!
Old 02-27-2005, 12:55 PM
dice daniels dice daniels is offline
Re: 87 honda accord speaker wiring diagram
Have you taken your door panels off and noted the color of the wires that are attached to your speakers? Sometimes that works. But then again alot of times I've found that somewhere between the hu and speaker the color code changes. And if your car has a factory amp the colors will most likely not match. you can always send a signal the oposite direction through the wire (via "cable toner" walkman,cheapo radio etc) and use a speaker "toner probe" to track it down under the dash board. as for the power and acc all you need is a test light and your keys. if the power is constant in any of the wires (with your dash lights off) you have your power wire. And if the power turns on and off with the key (with your dash lights off) you have your acc. The reason I say "with your dash lights off", is because the lights in alot of factory stereos turn on and off with the dash lights and you dont want to hook your deck up to it because you wont be able to turn it on unless your lights are on and It would most likely make your dash lights flicker with the music which is'nt as cool of an illusion as it sounds.
as for the speaker wires if they give you too much trouble I'd tape up the ends and run new wires.
REMEMBER to use zip ties,solder and heat shrink. I can't stand pulling out a deck and seeing a bunch of electrical tape wrapped around the harness cuz I know that underneith it I'm gona' find a sticky mess that the tape left behind. And butt conectors are over rated. All they do is provide a weak point in the wiring and create more trouble than they're wourth. I always solder and heatshrink my wires and I have "never" had any problems with them.
Old 02-28-2005, 09:12 AM
Re: Re: 87 honda accord speaker wiring diagram
Thanks, I know I can do all that you note, however my time is very limited as was hoping to simply hook up a deck.
Old 02-28-2005, 06:26 PM
I guess when a man asks a specific question he wants a specific answer. I'll do some surchn' 4 ya and see what I can find out.
Old 02-28-2005, 06:34 PM
Red/Yellow = R rear + : Blue/yellow = L rear + : Yellow/red = 12v access
Blue/wht = 12 v const : Red/Blk = Illum : Blue/Grn = L Frnt +
Red/grn = R frnt + : Brwn/wht = R rear + : Grey/wht L rear -
Grey/black = L frnt - : Brwn/blk = R frnt - :
Is this better?
Old 03-02-2005, 06:13 PM
Yes, thanks so much!
Old 03-02-2005, 07:50 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
show off
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
