Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-25-2005, 01:09 PM
albert3029 albert3029 is offline
Question stang has the shakes!
Whats up guys!! I have a 94 mustang Gt, my battery gauge for some reason is going crazy does not keep still and when idling it goes below normal, also car shakes when idling. Just replaced alternator and battery gauges continues to move and car shakes, anyone experienced this before any suggestions?? thx!
Old 02-25-2005, 08:36 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: stang has the shakes!
What's the tach read when it idles? Does the shakes go away when you drive? More info please.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-26-2005, 05:52 PM
THX FOR REPLYING, WHEN I'M DRIVING THE BATTERY GAUGE IS NORMAL DOESN'T MOVE AT ALL, BUT WHEN I'M AT A TRAFFIC LIGHT OR JUST IDLING IT MOVES AROUND, SOMETIMES MY MUSIC SYSTEM SHUTS OFF FOR A FEW SECONDS ALSO. NOT SURE IF ITS THE GROUND CABLE OR WHAT, JUST REPLACE THE ALTERNATOR, NOT SURE WHATS THE PROBLEM. THX!
Old 02-27-2005, 11:01 PM
mikev08826 mikev08826 is offline
Do you have underdrive pulleys??? If so, take them off.
Old 02-28-2005, 06:25 AM
HiFlow5 0's Avatar
Stanger
Re: Re: stang has the shakes!
What does the tach read at idle????????????
-2013 Ford Flex
-1999 Ford F150
Old 03-04-2005, 09:46 AM
Nope no underdrive pulleys.
Old 03-04-2005, 09:48 AM
Re: Re: Re: stang has the shakes!
It reads at about 600.
Old 04-02-2005, 06:59 PM
ribsey ribsey is offline
I had a similar problem and found that there is a small wire running from the Negative battery terminal cable. It runs and grounds to the front clip right by the rubber hood snub. Mine was loose and my battery kept dying and my stereo would clip out. Worth a look at anyways.
Old 04-04-2005, 08:09 PM
Mudstang Mudstang is offline
Send a message via AIM to Mudstang
hey i have a 93 5.0 h/o and my battery gauge does the same thing but i have underdrive pullies and it started after i put them on, as for the shakes ur timing might need adjusted i am not positive about this but that idle seems a little low.
