Five speed for '79 TA
I am thinking about going with a Tremec five speed to get the (interstate) RPM down to a reasonable number. I have a '79 400/4speed. What do you guys think, and are there any gotcha's with doing this swap? Here is a URL I have been looking at:
http://www.5speedtransmissions.com/gm_3550_package.html I would be going with the 600 ft. lbs. style, since I may do some engine swapping later. Let me know what you think. Thanks. |
Re: Five speed for '79 TA
You HAVE a 400/4 speed 79 !?? If it is original and matching numbers, you'd be crazy to swap or alter the car in any way! If it is not , go right ahead. But if it is I'd stay away from it, just check how many of those they produced, in the last year for the 400! |
It's your car, do with it as you see fit. They made more F-Body Pontiac's in '79 than any other year. If you drive it, and plan on keeping it, go for it! Enjoy it. That's what these cars were built for. If you bought this thing as an investment to one day turn around and resell, then I'd consider leaving it original as this will usually bring in the most $$ for it. But, in the end, it's your car. You know better than anyone else what your intentions are with it. I think this will tell you what to do. Besides, there are already plenty of museum cars out there and what fun are those? They sit and collect dust. good luck! |
as said before it is your car but if you want the best of both worlds it is actually better if you yank that tranny and use something else to keep the miles off the original if it is and having two trannies will actually raise the value. plus the 5-speed will put less stress on the engine and make it last longer. i didn't see any mods like cutting the driveshaft or anything like that but double check to make sure that the floor openning is large enough and the speedo cable is long enough as well as the drive shaft being the correct length and having the correct yoke and splines. also make sure that the crossmember will not have to be change or modified. have fun and good luck
Re: Re: Five speed for '79 TA
Yes, it is a 400/4 speed. It is numbers matching. And it has other options/missing options that make it more rare than some (no T-tops for instance). But you must know that it is also the lowest valued of all the TA years up through '79. This car was about 2400 produced, equipment wise, but not considering color. The changes will not make the car worth less for two reasons. First, I would be keeping all of the original parts, and second there are only two mods needed to make the change from what the manufacturer/sales company is saying - two holes in the transmission crossmember mounting points, and some minor trimming around the shifter entrance point. The other changes (driveshaft) would be buy a new one, keep the old one. I was actually asking about mechanical stuff, not about the concept. But I have thought about the concept as well, which is why I would be keeping all old parts and they would go with the car if it was sold (not likely). |
Re: Re: Re: Five speed for '79 TA
