Old 02-25-2005, 12:38 PM
leaking leaking is offline
Question only 2 cylinders firing
my son has a 96 escort that is only firing on 2 cylinders. but we don't know why . any ideas ?
Old 02-25-2005, 12:42 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: only 2 cylinders firing
going to need a whole bunch more infomation. Like motor size, maintance, and symptoms.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 02-25-2005, 12:47 PM
it's a 1.9 it will only get up to about 45we have replaced plugs , wires, dist. , we replaced the computer, nothing works. we took it to ammco to be checked AND THATS WHEN THEY TOLD US IT WAS ONLY FIRING ON 2 CYLINDERS.
Old 02-25-2005, 03:15 PM
chevyn0va1's Avatar
Re: Re: only 2 cylinders firing
it's a 1.9 it will only get up to about 45 we have replaced plugs , wires, dist. , we replaced the computer, nothing works. we took it to ammco to be checked AND THATS WHEN THEY TOLD US IT WAS ONLY FIRING ON 2 CYLINDERS.
control/ignition module? have you check the coil
Old 02-25-2005, 06:50 PM
A. Souphound A. Souphound is offline
a. Have you tried to pull up the computer trouble codes? What are they?
b. Do you know which cylinders are not firing? Are the two not firing adjacent to each other?.... Perform a compression test.
c. All your efforts have been directed toward the engine electrical side. As chevyn0va1 requested, we need to know what type fuel injection system your engine has.
d. Does the engine back-fire or make any other abnormal noises?
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 02-25-2005, 11:33 PM
jman63 jman63 is offline
mine acted up like that twice over the past few years...both times it was the coil pack...it may be worth checking to see if all four coils are firing.
Old 03-06-2005, 10:24 PM
BKFT_HOTRODER BKFT_HOTRODER is offline
Never run a vehicle with a miss because it will cause your cat to melt down and plug, they are expensive to change.
Old 03-07-2005, 07:09 PM
alleygm alleygm is offline
It's a 96 so more than likely its EFI.. I'd suggest 2 of the above things first, and after you have done them, you will know more than likely what your issue is.
1) check for spark on all wires.
a. Bad coil pack
b. Bad ignition module
2) compression check
a. Blow head gasket
b. Rings
Was the engine smoking before it started this? If so what color smoke?
