Old 02-25-2005, 10:47 AM
jason322 jason322 is offline
Key won't turn past aux.
okay here's the deal. I can't get the key to turn past aux. I'm thinking its the ignition cylinder that is just bad and I just need to replace it but I just wanted to make sure that this is the likely solution. I also have a bad camshaft sensor I don't think this would be the problem.
Old 02-25-2005, 11:02 AM
public's Avatar
public public is offline
Re: Key won't turn past aux.
Key Switch. You probably got it. You may try pressing the brake and moving the shifter to see if it is the interupter.
Yes, I am retarded.
Old 02-25-2005, 11:11 AM
clutch and brake are pressed. Car in neutral.
And I've had no problem with the clutch engaging and disengaging so that should be fine.
Old 02-25-2005, 11:15 AM
public's Avatar
Yep! I'd say the key cylinder is toast.
Yes, I am retarded.
Old 02-26-2005, 10:02 PM
noshun's Avatar
noshun noshun is offline
Re: Re: Key won't turn past aux.
did you try turning the hwell while doing the brake and such?!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 02-27-2005, 10:35 PM
yeah I've tried brake clutch moving the wheel even letting it roll a little. Nothing helps.
Old 03-01-2005, 04:30 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Have you tried your spare KEY?
Old 03-01-2005, 04:52 PM
Yeah. The other day it was doing it and I used the spare key and it worked right away but when I tired it right before I posted this it wouldn't work. I even tried flipping the key over and crap but nothing worked.
Old 03-02-2005, 11:08 AM
Austin8214's Avatar
Sounds like your key cylinder is junk then.
Old 03-02-2005, 03:35 PM
I got it replaced yesterday. Yeah that was the problem. To seperate the cylinder and the holder it goes in we had to use a hammer and it broke piece of the old cylinder off. So yeah something was catching.
