Old 02-25-2005, 08:43 AM
blazee's Avatar
blazee blazee is offline
Problem?
**Recall Info** 1998 Blazer
I am just posting some recall info that I found. Not all vehicles are covered by the recalls, so they may not apply to you.
Campaign Number: 00V220000 Date: 2000-Aug-11
Component:
Exterior Lighting
Defect Summary:
VEHICLE DESCRIPTION: LIGHT DUTY PICKUP TRUCKS AND SPORT UTILITY VEHICLES. THESE VEHICLES FAIL TO COMPLY WITH THE REQUIREMENTS OF FMVSS NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THE DAYTIME RUNNING LIGHTS BUILT WITH A CANDELA VALUE GREATER THAN 3,000 CANNOT BE MOUNTED HIGHER THAN 864MM ABOVE THE ROAD SURFACE.
Consequence Summary:
THESE VEHICLES DO NOT COMPLY WITH REQUIREMENTS OF FMVSS NO. 108.
Corrective Summary:
DEALERS WILL INSTALL A REVISED WIRING HARNESS THAT CHANGES THE DRL'S FROM HIGH BEAM TO LOW BEAM DRL'S, AND INSTALL NEW LONG-LIFE LOW BEAM BULBS. To schedule service online click here
Campaign Number:
98V053000 Date: 1998-Mar-09
Component:
Suspension: Front: Control Arm: Lower Arm
Defect Summary:
VEHICLE DESCRIPTION: MULTI-PURPOSE PASSENGER VEHICLE EQUIPPED WITH 4-WHEEL DRIVE OR ALL-WHEEL-DRIVE. ONE OR BOTH OF THE ATTACHING NUTS FOR THE RIGHT-HAND LOWER CONTROL ARM ARE UNDER TORQUED. THIS CAN ALLOW THE ATTACHMENT BOLT TO LOOSEN AND SUBSEQUENT BREAK RESULTING IN SEPARATION OF THE LOWER CONTROL ARM FROM THE FRAME.
THIS CONDITION CAN RESULT IN A LOSS OF VEHICLE CONTROL.
Corrective Summary:
DEALERS WILL INSPECT AND RETIGHTEN THE RIGHT-HAND LOWER CONTROL ARM NUTS TO THE PROPER TORQUE SPECIFICATION. To schedule service online click here
Campaign Number:
97V218000 Date: 1997-Nov-24
Component:
Service Brakes, Hydraulic: Foundation Components: Hoses, Lines/piping, And Fittings
Defect Summary:
VEHICLE DESCRIPTION: LIGHT DUTY PICKUP TRUCKS AND MULTI-PURPOSE PASSENGER VEHICLES. A FATIGUE FRACTURE OF THE REAR AXLE RIGHT-HAND BRAKE PIPE CAN OCCUR CAUSING A SLOW BRAKE FLUID LEAK RESULTING IN A SOFT BRAKE PEDAL. IF THE BRAKE PIPE BREAKS, THE DRIVER WOULD EXPERIENCE A SUDDEN DROP IN THE BRAKE PEDAL, THE INSTRUMENT PANEL BRAKE LIGHT WOULD ILLUMINATE, AND THERE WOULD BE A LOSS OF REAR BRAKE PERFORMANCE.
PARTIAL LOSS OF BRAKING AT A TIME WHEN MINIMUM STOPPING DISTANCE WAS REQUIRED COULD RESULT IN A VEHICLE CRASH.
Corrective Summary:
DEALERS WILL INSPECT AND REPLACE THE BRAKE PIPE. To schedule service online click here
Old 06-22-2005, 06:19 PM
blazee's Avatar
Problem?
Re: **Recall Info** 1998 Blazer
Old 06-22-2005, 07:42 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
thanks blazee, alwase looken out
