Old 02-25-2005, 08:41 AM
blazee's Avatar
blazee blazee is offline
Problem?
**Recall Info** 2000 Blazer
I am just posting some recall info that I found. Not all vehicles are covered by the recalls, so they may not apply to you.
Campaign Number: 01V364000 Date: 2001-Dec-03
Component:
Exterior Lighting: Brake Lights: Switch
Defect Summary:
VEHICLE DESCRIPTION: SPORT UTILITY VEHICLES. THE MULTIFUNCTION SWITCH COULD DEVELOP AN OPEN CIRCUIT CONDITION THAT RESULTS IN THE STOP LAMPS AND THE REAR HAZARD LAMPS BECOMING INOPERATIVE. THE CENTER HIGH MOUNTED STOP LAMP AND TURN SIGNAL FUNCTIONS ARE NOT AFFECTED.
Consequence Summary:
THE LOSS OF STOP LAMPS AND REAR HAZARD LAMPS COULD FAIL TO WARN A FOLLOWING DRIVER THAT THE VEHICLE IS BRAKING AND/OR IS STOPPED AND COULD RESULT IN A CRASH.
Corrective Summary:
DEALERS WILL REPLACE THE HAZARD SWITCH CARRIER. OWNER NOTIFICATION WILL BE CONDUCTED IN TWO PHASES. THE FIRST PHASE BEGAN APRIL 15, 2002, WITH MAILINGS TO OWNERS OF 2000 AND EARLY 2001 VEHICLES. THE SECOND MAILING PHASE WILL BE TO REMAINING 2001 AND 2002 VEHICLES. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT CHEVROLET AT 1-800-222-1020, GMC AT 1-800-462-8782, OR OLDSMOBILE AT 1-800-442-6537. To schedule service online click here
Campaign Number:
Component:
Exterior Lighting: Hazard Flashing Warning Lights: Switch
Defect Summary:
Corrective Summary:
Campaign Number:
00V228003 Date: 2000-Aug-07
Component:
Seat Belts: Front: Buckle Assembly
Defect Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES, LIGHT DUTY TRUCKS, SPORT UTILITY VEHICLES, AND MINI VANS EQUIPPED WITH TRW SEAT BELT BUCKLE ASSEMBLIES. THE BUCKLE BASE OF THESE SEAT BELT ASSEMBLIES WERE NOT PROPERLY HEAT TREATED AND THEREFORE DO NOT PASS THE LOAD BEARING REQUIREMENT OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 209, "SEAT BELT ASSEMBLIES."
IN THE EVENT OF A VEHICLE CRASH, THE OCCUPANT MAY NOT BE PROPERLY RESTRAINED.
Corrective Summary:
DEALERS WILL INSPECT THE VEHICLE'S REAR SAFETY BELT BUCKLE ASSEMBLY DATE CODES AND, IF NECESSARY, WILL REPLACE ANY REAR SAFETY BELT BUCKLE ASSEMBLY. To schedule service online click here
Campaign Number:
99V220000 Date: 1999-Aug-11
Component:
Service Brakes, Hydraulic: Antilock
Defect Summary:
VEHICLE DESCRIPTION: S -TRUCKS EQUIPPED WITH 2 WHEEL DRIVE. THESE VEHICLES MAY HAVE HAD THE RIGHT-HAND ANTILOCK BRAKE SYSTEM (ABS) MODULE FEED PIPE AND/OR BRAKE CROSSOVER PIPE TUBE NUTS TIGHTENED WITHOUT SEATING THE PIPE-FLARED-ENDS ENOUGH TO WITHSTAND NORMAL ASSEMBLY AND VEHICLE INPUTS WITHOUT PARTIALLY UNSEATING. THIS DOES NOT COMPLY WITH REQUIREMENTS OF FMVSS NO. 105, "HYDRAULIC SERVICE BRAKE NORMAL, EMERGENCY, AND PARK BRAKING PERFORMANCE."
IF THIS OCCURRED, THE SEATING SEAL COULD BE BROKEN DURING VEHICLE ASSEMBLY, OR FROM EARLY ROAD INPUTS OR BRAKE FLUID CYCLING, AND A LEAK COULD OCCUR INCREASING THE BRAKE STOPPING DISTANCE.
Corrective Summary:
DEALERS WILL INSPECT THE BRAKE PIPE UNION FOR SIGNS OF BRAKE FLUID, AND IF NECESSARY, INSTALL A NEW BRAKE PIPE UNION. To schedule service online click here
Old 06-22-2005, 06:18 PM
blazee's Avatar
Problem?
Re: **Recall Info** 2000 Blazer
