Old 02-25-2005, 06:36 AM
jessb83 jessb83 is offline
Suspension and Tach Question
Yeasterday i noticed that when i took a corner kinda sharp that there was a squeeking coming from the rear driverside. i wasnt on my brakes so i know thats not the problem. When i got home i got out and pumped on the diversside rear right over the tire and squeeky, squeeky. I also noticed that i can push on the body (drivers rear quarter panel right above the tire agian) and the body will move side to side about 2-4 inches and squeek un godly bad in the process. Idont remember that much side to side movement in the rear end of my 91 camaro but i never tested it it this normal for a 90 rs with a v-6? second is just i cusriousity thing what should my rpms be at 75-80 with a 3.1 v-6 and a automatic tranny? mine sit between 3500 and 4000 rpms. My crappy ford t-bird with a v-6 doesnt sit that high at those speed so i was just curious it thats correct or if my tach or even speedo is off. Thanks for all the help guys, please keep it comin.
Thanks,
Jess
Old 02-25-2005, 10:54 AM
Twitch1's Avatar
Twitch1 Twitch1 is offline
Re: Suspension and Tach Question
Bodies on any cars are not supposed to move at all as they are connected to the chassis! Better get under there and see what is amiss.
1973 Z-28
1965 Nova
1950 Packard
1996 El Dorado Touring Coupe
There is no substitute for cubic inches
Old 02-25-2005, 11:54 AM
Thats what i thought, but i dont know what to look for, the sway bar and all its bushings are good, the hinged things that connect the axle to the unibody dont move when its being pushed side to side, i dont know where anything else that could cause this problem is. and the tire moves with the car just not as much. i just though, could the hub assemble need to be replaced or maybe even tighten up the lug nuts? i just realized that i never checked the lug nuts sense i bought the car a week and a half ago. Im usually pretty good at trouble shooting but i dont know anything about suspension and rear ends of cars so please give me as much input as possible thanks again guys. Ohh any idea's about the tach/rpms part of my original post?
Jess
Old 02-25-2005, 12:34 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
What are ur gears? is the car stock?
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 02-27-2005, 04:23 PM
It was the tracking arm. The arm got beent sometime recently (dont know how that could have happened?) and it all but knocked the bolt that connected it to the body out of the bracket. I changed it yesterday and about 1.5 hours a 2 ligt bulbs for my drop light later, and after the assistance of a hammer, a crobar and a 4-way lug wrench i had the know tracking arm on and the car rides like a camaro should.
Thanks,
Jess
