Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-25-2005, 01:41 AM
HontegraGSI HontegraGSI is offline
Idling Problems on my GSR
Hi ok i have a 95 gsr that has 180k miles on it. when i start the car, it my tach goes to 1000 rpm. then as i drive then stop it goes down below and starts shaking like crazy. i gotta give the gas a little, but does anyone know how to fix this? yes i know i have a lot of miles on it, but i'm not ready for rebuild. so whats the main problem? alternator? throttle?? please help me...
Old 02-25-2005, 01:42 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Idling Problems on my GSR
any codes ?
Team Lonely Drivers
Old 02-25-2005, 01:44 AM
abs, but i'm guessing that doesnt have anything to do with engine... or does it?
Old 03-01-2005, 12:01 PM
93gsrswp 93gsrswp is offline
idle
It is probably either a vaccum hose has come loose or has a leak or your idle-air control valve. try adjusting your throttle body adjustment screw first.
Old 03-01-2005, 02:12 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Don't adjust the idle screw until you know that there are no vacuum leaks and that the IACV, TPS, and MAP sensors are good.
