Old 02-24-2005, 11:43 PM
Powerefx Powerefx is offline
Disconnecting the fuel lines
I came across the problem that i had to disconect the fuel lines while i was working on my engine. Now my Haynes maual says to get custom couplers to remove the springs, and to get new o rings. Is there another way i can take out the line, and do i have to replace the o rings?
Old 02-25-2005, 04:30 AM
benchtest benchtest is offline
Re: Disconnecting the fuel lines
1) What are you working on? 2) Your post is a bit confusing...have you, or have you not disconnected the fuel lines?
Remember: Don't confuse noise with horsepower! and Junk is junk, even when it's on sale!
"I would never doubt your expertise....it's obvious you wrote the book on stupidity!" DD
Old 02-25-2005, 09:04 AM
im working on a 93 ford escort, and i have NOT yet disconnected them yet, i want to see if the couplers are necessary to discconect them, or is there another way i can do it?
Old 02-27-2005, 09:23 PM
Yes, you need the tools to disconnect the lines. They're cheap and available readily. I've never replaced the o-rings for a one-time, first-time disconnect, but you should take a look at them to be sure they are not damaged. Also, be sure the fuel pressure is ZERO before you disconnect the lines.
