sputtering
I just bought this Aurora and am having a problem with it. When I am at about 40-45 MPH and slightly on the gas the car seems to sputter really bad. Also in this same situation when I press on the gas it doesnt respond until I press hard enough to accelerate, which is when the rough sputtering starts. Any suggestions?
I had a similar problem in my 95 Aurora. I had no power and sputtering at low and high RPM's but not all the time. It turned out that a coil pack was bad. Have those checked. You can do it yourself, but I'm not 100% sure how.
Re: sputtering
are you using 93 octane?
1997 Burgandy Aurora |
Re: sputtering
Ref:- the o2 sensors check out this thread.
There is some info about 95's http://aurorah.proboards20.com/index...num=1091249942
1996 Aurora Black / grey |
Re: Re: sputtering
That should really help you out.
i change the plugs, air cleaner and adde fuel treatment for the injectors. seems to be better. the air cleaner was so dirty that you couldnt see a halogen light through it.
