Old 02-24-2005, 08:07 PM
skibum2 skibum2 is offline
Non blinking turn signal-94 Cherokee Sport
Hi, can anyone tell me why my left turn signal does not blink on my 94 Cherokee although the turn signal light seems to come on in the back and the right turn signal works fine. Is this something simple or something I should have someone else do. I am a novice at fixing mechanical things. Thanks for any input.
Old 03-16-2005, 06:05 PM
hytek1969 hytek1969 is offline
Re: Non blinking turn signal-94 Cherokee Sport
Possible bad bulb or bad flasher relay. The relay on my 99 Cherokee is to the left behind dash underneath steering column, if that makes any sense.Hope that helps
Old 03-18-2005, 09:16 AM
Cool
Thanks for the info. I changed the bulb with no luck, so perhaps it is the relay.
Old 03-18-2005, 08:21 PM
stevelock's Avatar
stevelock stevelock is offline
Send a message via ICQ to stevelock Send a message via Yahoo to stevelock
left front bulb is shorted (replace it )or you have a wire short by the front bulb to ground.
just my quess. were I would start.
good luck
1997 Jeep Grand Cherokee Laredo 4WD, 4.0L I-6 (Hers)
1996 Jeep Sport 4WD, 4.0L I-6 (mine)
Old 03-19-2005, 01:30 PM
Saudade's Avatar
Saudade Saudade is offline
Does the emergency (4way) flasher work on all 4 lights? Sounds more like a wiring problem.
Old 03-19-2005, 04:03 PM
stevelock's Avatar
Re: Re: Non blinking turn signal-94 Cherokee Sport
yes but i have seen if the button is halfway out it can do some odd things
