Old 02-24-2005, 07:58 PM
JuanPollo's Avatar
JuanPollo JuanPollo is offline
Angry Need help with Aztek airbrush
This sucks I'm trying to paint something for my friend with my Aztek Airbrush but nothing comes out. I've even bought a new tip for it and still nothing. I'm sure there is an answer out their but i'm feed up and have little to no paitence. I appreciate all of your help.
Old 02-24-2005, 08:05 PM
Vric's Avatar
Vric Vric is offline
Re: Need help with Aztek airbrush
did you thin the paint ?
Old 02-24-2005, 08:06 PM
freakray freakray is offline
AF Modelrater
What model?
Gravity feed or syphon feed?
Type of paint?
Was the paint thinned?
What air pressure?
AF User Guidelines
Old 02-24-2005, 08:55 PM
JuanPollo's Avatar
Syphon feed, of course thinned, tamiya acrylic, low-mid pressure, not sure what model but I got it a Wal mart.
Old 02-24-2005, 09:10 PM
AF Modelrater
Thinned with what?
AF User Guidelines
Old 02-24-2005, 10:57 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
If you're not getting anything coming out, there must be a cog someplace, or the nozzle isn't installed properly. It could also be a leak in the airline, either where it mates to the air supply or in the hose itself: If had that drop pressure from the can so much that it would barely shoot paint.
You may have thinned the Tamiya paint with the wrong medium: Always use Tamiya thinner or 90% isopropyl alcohol. Other kinds of thinners can cause the paint to get lumpy and also clog the airbrush (This happened to me as well, using enamel thinner with Pactra's lacquer R/C paint).
Worst-case is that you send the airbrush to Testors and they send you a new one.
Old 02-25-2005, 06:02 PM
JuanPollo's Avatar
I use Tamiya thin with tamiya paint, cleaned out the entire thing, doe any one know if switched to a gravity feed one would be better? Once again thank you.
Old 02-25-2005, 06:23 PM
Fkouch's Avatar
Fkouch Fkouch is offline
Then you're taking up the wrong hobby
Current Projects
Yamaha YZF-R1 Taira 70% complete
Lamborghini Diablo SE30 (Fujimi/Revell combi) 20% complete
Tamiya Ferrari Enzo plus SMS, Sakatsu and Acustion 10% complete.
Old 02-25-2005, 07:25 PM
kicth's Avatar
kicth kicth is offline
I think it is not the matter if it is a gravity feed or a syphon feed. Maybe you didnt thin your paint enough.
I used Tamiya Paint and Tamiya Thin as well, if you dont thin it enough, it still wont come out from the airbrush.
Adding a drop or two each time and try again see if it works.
I am a beginner as well, all you need is patience and keep trying different methods or other possibilities when you are stuck at something, it will end up coming out all good if not better.
Old 02-26-2005, 12:29 AM
JuanPollo's Avatar
I put that no patience part because my friend is pressuring me into finishing his Volkswagen emblem. Overall I have patience when it comes to working but when my tools let me down is when I get frustrated.
Old 02-26-2005, 05:09 AM
phase5's Avatar
phase5 phase5 is offline
is there any air coming out of the nozzle at all. as the aztec range is common for unclipping internaly and stops working.And sometimes the needle gets stuck remove the nozzle and check if needle will move.
glue glue and more glue
www.djamos69.com
Old 02-26-2005, 06:28 AM
klutz_100's Avatar
maybe stupid thought but I had a similar problem. Turned out that the small "pipe" connecting the gravity feed cups and syphon bottles to the airbrush main body had got clogged with residual gunk. cleaned them out with thinned down toothpicks and then it worked fine.
Old 02-26-2005, 04:53 PM
JuanPollo's Avatar
air is coming out of the nozzle I;ve even tried water and it doesen't work I'll try that tip klutz 100 said.
