Old 02-24-2005, 06:47 PM
mother_russia mother_russia is offline
Is it safe?
My 10 inch sub has 8 screw holes going around the edge to hold it in the box. With the circumstances of my box, however, the screw nearest the top of the box and the screw nearest the bottom of the box, will be so close to the edge that i am afraid they will crack the wood. If i left these two screw holes empty, and only screwed in the sub with the remaining 6 screws, will i run into trouble or will the 6 screws be enough to hold the sub in as well as properly seal it? its a 3/4 inch thick fiberboard box, so i think it should probably work. input please.
Old 02-24-2005, 06:54 PM
Powerefx Powerefx is offline
Re: Is it safe?
Well not really sure, but i mean if its so close to the edge, your sub overtime might even cause it to crack. So build a new box.
Old 02-24-2005, 07:11 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Is it safe?
No you are perfectly fine. Ive seen DD 9917's held in place by only 3 bolts.... just because there are 8 holes doesnt mean you have to use all 8 to secure the woofer properly. you are fine with 6....
Old 02-24-2005, 07:47 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Is it safe?
My buddy Scott had two 12" Solobaric Kickers and i think he had 8 screws between the two. I don't think it matters that much....but that was a vented box so seal isn't really as important.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 02-24-2005, 08:45 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Is it safe?
actually its just as important to keep a seal on the ported box because if not it fucks up the tuning unless its minimal air loss.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-25-2005, 12:38 AM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Is it safe?
I'd say you're fine as longs as the sub ahs a rubber gasket around the basket! WOOT a rhyme...lol. But if it's plain metal against the mdf, then i'd at least get weather stripping to go between the two b4 your screw the 6 screws in! Then you'll be set!
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 02-25-2005, 06:18 AM
yeah, it has a rubber seal. i think it will work out, thanks.
Old 02-25-2005, 02:31 PM
ngsm13's Avatar
Re: Is it safe?
No problem! What's your setup by the way!?
NG
Old 02-25-2005, 10:27 PM
1 jl audio 10w6 (small car, it'll be good), profile ca600 amp, alpine 9831
