Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 02-24-2005, 07:09 PM   #1
zetapsi538
Keyless Entry Programming
I need to know how to program a 2002 blazer key fob. I tried the steps for a 2000, but it didn't work. I tried:
Hold down unlock on door panel
Turn ON OFF ON OFF
Release unlock button
Hold lock and Unlock on Remote.
I think its supposed to acknowledge that its entered programming mode, but knothing happens.
Thanks
zetapsi538 is offline   Reply With Quote
Old 02-25-2005, 06:34 AM   #2
ricksza
ricksza's Avatar
Re: Keyless Entry Programming
Turn ON OFF ON OFF
Thanks
Sorry, time to visit the dealer.
Transmitter Programming
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Install a scan tool.
Use the scan tool in order to access the Body Control Module (BCM) Special Function or Module Setup: Program Key Fobs.
Press the START soft key on the scan tool.
Important: The scan tool must stay connected until all of the transmitters are programmed.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
Repeat the previous step in order to program up to 4 transmitters.
Remove the scan tool.
Operate the transmitter functions in order to verify correct system operation.
ricksza is offline   Reply With Quote
Old 02-26-2005, 08:21 PM   #3
crespo32
Talking Re: Keyless Entry Programming
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
crespo32 is offline   Reply With Quote
Old 09-30-2005, 11:09 AM   #4
NANCIEMARIE
Re: Re: Keyless Entry Programming
THANK YOU SO MUCH. FINALLY AFTER MUCH BANGING MY HEAD AGAINST THE WALL , I CAME ACROSS YOUR SITE AND IT WORKED MIRACLES . MY KEYLESS REMOTE CLICKERS ARE FINALLY WORKING. YOU ARE WONDERFUL ............THIS SITE IS WONDERFUL. :...........I WILL TELL ALL OF MY FRIENDS AND COWORKERS ABOUT IT.!!!!!!!!!!!!!!
NANCIEMARIE is offline   Reply With Quote
Old 09-30-2005, 10:46 PM   #5
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
does anyone know how to program a keyless entry remote on a 1995?
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
