Old 02-24-2005, 04:38 PM
omaro86 omaro86 is offline
HKS BOV install
What's up Im new here, got the car about 3 months ago, I just ordered the install kit for it for the hks ssqv bov, and I just have one question. On the stock bov it goes into the intake pipe underneath the y-pipe.... what am I supposed to do with what will be a big empty hole there??? anything else i should know?? thanks....
Old 02-24-2005, 05:07 PM
Igovert500's Avatar
blue + red light magnet
Re: HKS BOV install
http://www.team3s.com/~egross/3S/Mod...BOV/index.html
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-24-2005, 06:30 PM
The1NamedMarc's Avatar
The1NamedMarc The1NamedMarc is offline
Send a message via AIM to The1NamedMarc
Re: HKS BOV install
What year is your car? If it's 6 speed, the install kit may hit the shifting link. That's what happened to me at first.
So I just bought some radiator hose, at an Auto place, and connected the HKS near my battery.
[battery] |------|
[HKS]----|Y-Pipe|
[Intake] |------|
The tube, coming from the y-pipe and going into the HKS, is shaped like a "U". Just find a tube like that, without having to bend it, and try it out.
Old 02-24-2005, 07:21 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: HKS BOV install
I've done some research on the HKS, it costs about $200, but you need to get an adapter and weld it onto the intake and that sounds like a hastle. There is another option to get it with a kit that allows to mount it withought welding yet the price jumps an astonishing $140 for the kit... is there any way to get around the expense of the kit or the welding? Are all BOVs this difficult to mount? How much would a small insignifigant weld like this cost? It welds to the Y pipe right?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-24-2005, 09:36 PM
Igovert500's Avatar
Re: HKS BOV install
mine didnt require any welding, and only a $4 piece of radiator hose and a $2 radiator patch kit to relocate it a bit.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-24-2005, 10:41 PM
Thourun's Avatar
Re: HKS BOV install
So you just went to autozone or somthing? So that would work for any BOV?
1995 3000GT VR-4
Old 02-24-2005, 11:13 PM
Igovert500's Avatar
Re: HKS BOV install
Well I don't have personal experience with an HKS, but from the pictures on that link, there is no welding involved, it is almost identical installation to my GReddy. Is that metal pipe attached to the HKS BOV the $140 kit you were talking about? I havn't looked at an HKS up close in person, but it seems to me you could use a similar radiator pipe (to what I used) instead of that metal pipe, and get it to work fine with a couple of hose clamps.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-24-2005, 11:49 PM
Thourun's Avatar
Re: HKS BOV install
Well the kit that HKS makes to go along with it is just radiator pipe and some clamps I think, I just don't get how it ataches to the BOV since its like trying to attach a pipe to a hole.
1995 3000GT VR-4
Old 02-25-2005, 12:23 AM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: HKS BOV install
Is the TurboXS Type H-RFL ne good? Its fairley cheap and from what i herd is lives up to the RFL part but performance wise how does it stand?
Old 02-25-2005, 09:33 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: HKS BOV install
It seals with hex-screws and o-rings.
I have owned two (just for a week or two of amusement at the time) and they are not for performance...or perhaps 22+ PSI was the culprtit.
Kris
2012 Genesis Coupe 2.0t
Old 02-25-2005, 11:42 AM
Dreamspawn's Avatar
Re: HKS BOV install
They are rated for 25psi i only plan to u is with 14.5 psi. So do you think that would work? or take my money and invest in somehting else.
Old 02-25-2005, 03:00 PM
G35turbo G35turbo is offline
Re: HKS BOV install
mine is a turbo xs bov rfl and i had to do the samething, i went and bought a radiator hose and brought right by the battery.
Old 02-25-2005, 04:33 PM
Thourun's Avatar
Re: HKS BOV install
So how does the radiator hose attach to the BOV? I just can't picture it working easily.
1995 3000GT VR-4
Old 02-25-2005, 06:38 PM
Re: HKS BOV install
it goes from the Y pipe to the end of the BOV. I will post new pics of my car pretty soon and you can see.
Old 02-25-2005, 06:41 PM
Igovert500's Avatar
Re: HKS BOV install
The bov usually has isn't just an opening, it has a 'neck' on it, the radiator pipe slides over this neck, and you use hose clamps to tighten it down.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
