Ok first car with ABS brakes 94 bonny and wan ttoi ask a question here. today i applies pressur eon the brakes and they seemed to go to the floor car stops but maybe its me. Also today i was driving car infront of me stopped i applied brakes and car made a weird sound lont like the brakes rubbing but t grinding sound is this normal or not I just bought car ans hate it so much. Ok now if i step on brake ther is a click noise before i start itand i can feel it in the shift it on the floor not colum shifter. I need this car can you help. Car has traction control and was just supposodly inspected at the car lot!!!
Re: Not sure if i have a problem HELP
AS I understand, your car stops without problems, but the "noises" seem to annoy you.
My first suspicion is you have just got the car and not used to the behaviour of this ABS system. In the firstplace, it does a series of clicks and groans when turning the key on . That is normal. Then if it acts on, like in panic stop and some wheels want to lock, the action of the ABS is the kind of noise you describe,(releases and puts back brake pressure on specific wheels in rapid succession) and you have a feeling like the pedal goes to the floor but it does not really. So in as much as I can see, all is normal....If I missed the point, just come back. However, sometimes, the ABS becomes overreacting like it does it anytime you stop even in a mild stop, and then it does not help at all. In my case, it has died a long time ago, and I"m happy with it like that. RIP.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Originally Posted by Edsangel2 ok had to change the master cylinder had no brake pedal unless i really stepped on it. Ok after that the brake light came on fluid full and i did bench bleed the master so i unplugged it and it wne out seems i may have damaged it or got ti wet somehow so ill see what happens. ? Happy you have solved the problem.I remember sometimes it takes one or 2 hard braking pedal strokes to replace the sensor in neutral position and kill the light. (It will be interesting to keep a single thread so everyone who reads will see all previous posts pertaining to same subject. Updating the thread moves it to the top of the list anyway.)
