Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-24-2005, 02:50 PM
tipota tipota is offline
turbo and ECU question
im still new to all this, but from reading on the forum ive learned you need to upgrade your ECU to boost more than 5psi safley, in order to get the timing right so your enginge dosnt detonate. now, wouldnt the timing be different for different levels of boost? or does one upgraded ECU handle a large range of timings? i know people who drive the eclipse tune the car themselves to get timing and injection correct, but can you also do this to the nissans? especially after you have an upgraded ECU but want to boost even more.
Old 02-24-2005, 05:16 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: turbo and ECU question
upgrading your ecu is only one option.. its all about your fuel maps. the safc is very popular cause its cheap and very efficient. there are a couple of other options but safc is the best in my opinion. do that with new injectors if you're going turbo to start with.
1 degree of timing retarded for every psi is the general rule. ecu won't have any problems with this if its working properly.
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 02-24-2005, 05:29 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
It's half a degree for every PSI....or one degree for half a PSI...anyways, it's 1-1/2 or 1/2-1 but not 1-1.
Old 02-24-2005, 06:23 PM
D-Bo's Avatar
slip of the mind.. everything else is good i think
Old 02-24-2005, 07:22 PM
so, just to make sure i understand this, if i get the new ECU, the more i boost, the more it will automatically adjust the timing so i will be safe? i also heard that if i get the KA engine(which i eventually will) i need a new ECU, so i might as well get teh upgraded ECU at that time
