Old 02-24-2005, 02:34 PM
profox02's Avatar
profox02 profox02 is offline
Send a message via Yahoo to profox02
I Need A Winch
I GOT STUCK IN THE MUD YESTERDAY WITH MY '94 SILVERADO Z71 .. AND IT TOOK ONE NIGHT AND A DAY TO GET OUT...I NEED A GOOD WINCH...ANYONE KNOW WHERE I CAN GET ONE...A GOOD ONE..
Old 02-24-2005, 03:01 PM
profox02's Avatar
Re: I Need A Winch
ALSO WHEN IM LOOKING FOR ONE..DO I LOOK FOR ONE THAT PULL THE WEIGHT OF MY TRUCK OR DO I LOOK FOR HP OR Single Line Rated Pull....ANY INFO WOULD HELP..
Old 02-24-2005, 05:28 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Well getting stuck is no fun, As far as a good solid winch goes id get a Warn, There top of the line in quality and its going to cost you a good penny. When looking for the pulling power the more the better, Not only do you have the wieght of your truck you have the force of whatever its up against that you cannot get trough. Check out Warns website at: http://www.warn.com/ and they have a dealer locater.
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 02-24-2005, 08:41 PM
abaird abaird is offline
Re: I Need A Winch
If you were stuck that bad, would a winch really help? You will probably have to get a heavy duty bumper of some sort.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 02-24-2005, 09:13 PM
acewelderman's Avatar
acewelderman acewelderman is offline
Re: I Need A Winch
Big time heavy duty indeed!!Warn & ramsey make some nice ones.You need a bigger one for a full size 7 or 8k would do it.Single line is equal to the winches rating.Double mean you run a snatch block(pulley w/hook on it) at an anchor point(tree) This w/double the pull.And can pull you sideways if you need to.Like abaird says you will need bumper & mounts w/same type ratings!!!Also winches use LOTS of amps.Dual batteries or heavy duty elec, system is required.Hey I know a guy that could weld that up for you!!I call it my urban assault bumper.One more thing this stuff is heavy probly need a helper spring of some sort on a half ton
JUST WELD IT !!
Old 02-25-2005, 08:34 AM
profox02's Avatar
Re: I Need A Winch
thanks for the info...im thinking bout a "t-max"..how good are these winches...the one im looking at is rated at 11000 lbs...
Old 02-25-2005, 08:48 AM
rpreston rpreston is offline
Re: I Need A Winch
Hey Profox. Next time you get stuck, instead of a winch, get a wench. That way you won't even care...
[SIZE=3]"How do you feel about Women's rights?" " I like either side of them."[/size] - Groucho Marx
Old 02-25-2005, 11:14 AM
profox02's Avatar
Re: I Need A Winch
what!?....a wench?
Old 02-25-2005, 11:46 AM
Re: I Need A Winch
Yeah. You know, the female kind with the leather corsets...(minus the chastity belt)
Old 02-25-2005, 12:04 PM
profox02's Avatar
Re: I Need A Winch
Ok...ill Keep That In Mind
Old 02-25-2005, 12:07 PM
profox02's Avatar
Re: I Need A Winch
Also In Addition To A Winch..i Wanna Put In Some Rear Lockers....can I Do This With The Truck Being Stock???...i Was Thinking Bout The "powertrax" Systems.
Old 02-25-2005, 12:31 PM
Re: I Need A Winch
yeah you can put in a locker, I have always wanted to bu tcan't afford it. Powertrax, eaton, air lockers, they are all good.
2009 Silverado 1500
2005 Yamaha GP1300R
Old 02-25-2005, 12:41 PM
profox02's Avatar
Re: I Need A Winch
abaird...U SAID U WANTED TO PUT ONE IN..WHICH BRAND WOULD U USE....I AM THINKING OF USING POWERTRAX.
Old 02-25-2005, 01:09 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: I Need A Winch
I read an article that said most pulls don't go over 3,000 Lbs even on BIG trucks. I'd still say get a 9,000#+ winch, but you don't need that much unless you're going vertical. You can use a snatch block and run the cable back to your truck, that will double the pulling power. Look for one with a higher line speed. That way you can get out quick if you're not too deep, then use a snatch block if you're really stuck.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-25-2005, 01:18 PM
profox02's Avatar
Re: I Need A Winch
What Is A Snatch Block...and How Do U Use It???...sounds Like It Works Good
