Old 02-24-2005, 01:48 PM
Lafarga Lafarga is offline
Question about installing speakers
First of all, I would like to say that I know next to nothing about speakers and such, so any input will be appreciated. Ok. I was wondering if I could just cut the wires on my stock speakers and install new speakers using those wires. Is it possible to do that, or is using an amp and batteries and what not the better way to go?
Old 02-24-2005, 02:22 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: Question about installing speakers
What speakers are you replacing? What are you replacing them with? and yes, to run speakers off of your h/u you can use the stock wiring.
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 02-24-2005, 06:51 PM
Powerefx Powerefx is offline
If your runnin Coaxes, you can use the stock wires to you headunit. Im pretty sure it doesnt work with compnents, and even if it did, it wouldnt sound that great either
Old 02-24-2005, 07:13 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
run new wires unless your stock one's are pretty beastly. Also if you have a factory amp you can't do this.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-25-2005, 12:42 AM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Re: Question about installing speakers
Yeah you can...
Anyways,
To answer your question, as stated above you CAN do what you wanted. However, going with aftermarket speakers (especially components) will give you INFINITELY better sound (when used in conjuction with an amp!). peace
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 02-25-2005, 11:39 AM
Mannyb18b's Avatar
again, what speakers are you planning on replacing, and how much you plan to spend?
Alpine H/U-
CDT EF-61's
NSB-100
Old 02-25-2005, 12:08 PM
Not a factory amp.....usually those things only out out like 25 a channel. HU power would be cleaner n e ways.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-25-2005, 02:11 PM
ngsm13's Avatar
I did it with my girl's system before i got an amp for them...it works...
NG
ngsm13's Avatar
Oh, and ... BS on that...
NG
Old 02-25-2005, 03:30 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
stock wire in my truck is like 20awg.... since i am planning on sending about 100w RMS to the RE's after i get up the money to buy the amp i am going to go ahead and replace the wires into the doors anyway...its better, but not nessicary....
Old 02-25-2005, 06:06 PM
oooook w/e considering a lot of factory speaker like bose has fucked up impendace n e ways and you would clip the hell out of most factry amps with a after market HU turning it up very much at ALL.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
