Old 02-24-2005, 01:34 PM
tcfco2005 tcfco2005 is offline
Question Clunk
Its weird every time i try to take of quickly from a dead stop i hear and feal a big clunk coming from my car. Does anyone know what can be causing this
Old 02-24-2005, 01:37 PM
chevy_chic20041 chevy_chic20041 is offline
Send a message via Yahoo to chevy_chic20041
Re: Clunk
transmission mount
Old 02-24-2005, 01:39 PM
Re: Clunk
Do You think the transmission mount bolts are just loose or something
Old 02-24-2005, 01:51 PM
WeirdRich WeirdRich is offline
Send a message via AIM to WeirdRich Send a message via MSN to WeirdRich Send a message via Yahoo to WeirdRich
Re: Re: Clunk
mine came loose. I tightened them up and it was good as new. it happened again though...time to get a new one.
1994 Camaro Z28 Convertible 385
1981 Honda CB 750 Custom
Old 02-24-2005, 01:57 PM
Re: Re: Re: Clunk
Were you having the same problem as me
Old 02-24-2005, 02:22 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: Clunk
Dumb question, do you have like something heavin in your trunk that slides around? Do you hear the same sound when you slam on the brakes? If so, sounds like something is loose and bouncing around. If not, goto a good mechanic and ask 'em to take a look.
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 02-24-2005, 03:44 PM
Twitch1's Avatar
Twitch1 Twitch1 is offline
Re: Clunk
I literally could be anything on your car from a u-joint going bad to a loose suspension component. There is no "only" answer.
1973 Z-28
1965 Nova
1950 Packard
1996 El Dorado Touring Coupe
There is no substitute for cubic inches
Old 02-24-2005, 08:42 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Clunk
Most likely thing is the tranny mount. Dont bother tightening it just replace it if that's what it is. Could be your gears too.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 02-25-2005, 01:46 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Clunk
it's the transmission mount (like so many have said already). my friend broke three of them by doing neutral drops from a dead stop. if you're gonna keep driving hard get the 'poly' material mount.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 02-25-2005, 05:46 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Clunk
Tranny mount,motor mount, U-joints or rear end as has been mentioned but I would bet it was your tranny mount.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-25-2005, 12:57 PM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
Re: Clunk
same problem.. jacked it up and my tranny mount was shredded. GM uses a cheap rubber mount, it gets by for awhile, but you should probably upgrade to a polyurethane mount. got mine for 30 bucks, i think i ordered it from www.lmperformance.com
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
Old 02-25-2005, 01:08 PM
Re: Clunk
thanks yall for the help but i was wondering if i would neeed to use a car lift to see the transmission mounts or can i just crawl under my car and get to them from there.i can fit
Old 02-25-2005, 01:16 PM
Re: Clunk
if you can fit, it's located about halfway down the doors in the middle of the car.. should be attached to a crossmember that runs from the sides of the car. If you want to check to see if it's loose, bring a big screwdriver or something to pry it with and wedge it in there and try to wiggle it around. mine had a little play in it, but wasnt too bad..
Old 02-25-2005, 01:19 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Clunk
Use a jack and then put it on stands. or invite Lil Marcus/Korndogg/Ridgerunner over they are thin enough to fit under there.. Good Luck
John
Old 02-25-2005, 01:21 PM
Re: Clunk
not quite.. i had to jack my car up and put it on ramps.. because the ramps are to high for me to just drive up on them.. lol
