Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-24-2005, 12:20 PM
Sunbeam2 Sunbeam2 is offline
Angry help Cannot Pull Steering Damper
I bought a new Rancho Steering Damper and New Shocks from Quadratec.
I cannot get the steering damper rod off the center link, the rod is a conical shape that must be pulled out with a two jaw puller. I bought a 5 ton puller from sears and it snapped a jaw, I returned it and got a 7 ton puller and have so much pressure on it I am afraid to add anymore.
The darn thing just will not pop off the center link.
Any tricks of the trade out there, I have it up on jackstands and want to use the car tomorrow
Old 02-24-2005, 12:26 PM
mx52nv's Avatar
mx52nv mx52nv is offline
Re: help Cannot Pull Steering Damper
did you try knocking on the bolt from the front side with a hammer?
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 02-24-2005, 12:34 PM
Hitting it was the first thing I tried, then I went a got a pickle fork and that did not work, so I bought the 5 ton puller from Sears and broke it, now I have the 7 ton hanging on there and I have a pipe to put over the handle of my wrench for more leverage to force it more or break it too.
what about heat?????
Old 02-24-2005, 12:36 PM
JDPascal JDPascal is offline
There is a tool called a "pickle fork" that wedges in between the two parts to separate it. I only use it if I don't want to save the rod end.
The other way is to use two hammers. One on top side of the mounting hole for backing so the rod doesn't flex and strike the rod on the other side of the conical hole to "expand" it slightly. If you can get enough swing behind the blow, it will usually release the tapered stud.
JD
Old 02-24-2005, 12:38 PM
guess you already know bout the 'fork.... Did you use two hammers when you "hit it"??
JD
Old 02-24-2005, 12:55 PM
I have the puller on the rod now, I will try the hammer thing and get right back
Old 02-24-2005, 01:16 PM
two hammers did not work, I can not get a good swing laying on my back. I put the puller back on and have so much pressure on it now I am afraid the wrench might break.
Any other suggestions???? Please............
Old 02-24-2005, 01:55 PM
try a "tap" on the end of the puller forcing screw if you can get a swing at it.
JD
Old 02-24-2005, 02:04 PM
I got it out
With a load still on the puller I used a butane torch and after about a minute it just popped out.
Thanks for all the help
Old 02-24-2005, 02:09 PM
good goin'..
heat would have been my next try too. I just hesitate to use heat on a steering component even though it is below the temp that will affect the metal.
JD
Old 02-24-2005, 04:17 PM
mx52nv's Avatar
wow, I have never had that much trouble with mine. makes you wonder what they used to put it in there with.
current rides:
1990 Turbo Miata
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Old 02-24-2005, 06:05 PM
just one of those days!!!!
JD
Old 02-24-2005, 09:37 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Yea, I used a little Propane torch to heat the Drag Link up for a minute or 2 then a good hit on the drag link next to where the steering damper gets bolted onto. maybe even have to hit the bolt itself - make sure to put the nut on loosely so u don't mushroom the end of the bolt and cause more problems.
Old 02-25-2005, 11:08 AM
glass glass is offline
I had a similar problem with mine as well, using a cheap puller and soaking it overnight with penetrating oil popped it loose
