Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-24-2005, 11:51 AM
mx52nv's Avatar
mx52nv mx52nv is offline
ATF+3 in tcase?
I picked up some to change the fluid in the tcase. Any opinions on this?
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 02-24-2005, 12:16 PM
JDPascal JDPascal is offline
Re: ATF+3 in tcase?
My personal preference is to use a synthetic in the transfer case. The main job of the lube there is to reduce friction and keep the parts as cool as possible - no friction modifiers are required because there are no clutch packs.
The +3 will work just fine in the transfer case - (it was likey the factory fill) - as will any ATF product. The only time you might have a problem with a incompatible fluid is if a seldom found leak happens that allows the oil in the TC to be pumped into the transfer case.
Amsoil and Mobil 1 are likely the most familiar synthetics. I just happen to use the Mobil because I can find it easier.
JD
