Old 02-24-2005, 12:37 PM
nadamechanic nadamechanic is offline
98 Silverado Starting Problem
Good Morning!
I have a 1998 Silverado C1500 with a 5.0L V8. Since last Sunday, I've had two occasions (both first start of the day) where the engine will fire but not run. It turns over, sounds like it's started but immediately dies.
Possibilities???
1) The fuel pump does engage but I lifted the breather off and can't smell or feel any gas in the throttle body. Maybe fuel pressure? It's not all the time though.
2) I checked all relative relays and fuses in the engine compartment...they appear good.
3) After pulling and reinserting the fuses, I filled the bowl up with gas manually and it eventually started..after 15-20 minutes of off-and-on attempts. It doesn't die after it starts and then restarts just fine for a couple of days.
4) I filled up the tank last Saturday and did not have this problem prior to then..could it be bad gas? I have not used any injector cleaner or additive yet.
What could this be????
Thanks!
Old 02-24-2005, 01:12 PM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Re: 98 Silverado Starting Problem
http://www.automotiveforums.com/vbu...ighlight=tamper
Go look at that thread that I started. I had this exact type of intermittent problem (start and immediately die) and it drove me nuts for almost six months. I got all kinds of answers and opinions. If I had listened to everyone, I would have spent a thousand or more dollars and still not be fixed. I ended up fixing it myself for 99 cents. There's a good chance this is your problem too.
GM vehicles use VATS or PASSLOCK. Introduced in 1996, GM has changed the VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present during the start cycle. However, in the PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. This is why you no longer see the resistor actually in the key itself. This is still a theft-deterrent device.
To remotely start a car (in your case, I don't know if this is remote-start related) with this feature, you must bypass the PASSLOCK system. There are two methods of doing so.. The first, is to permanently bypass this system. This is the easiest method for accomplishing your task and this is what I did. The second way, is to temporarily bypass the PASSLOCK, by introducing relays into the system, which retain all of the features of the system, while allowing your remotes start module to bypass it automatically during a remote start cycle.
Also, even if you have no remote starter, you will have the same starting issues if this resistor circuit starts to go bad. The truck will enter "Tamper" mode and then you need to wait about 8 minutes, and then the truck computer will re-set and it may (or may not) start and run properly. It's a very random problem and cannot be located with a OBDII code reader.
Your '98 truck (like mine) uses PASSLOCK with the built-in resistor circuit, therefore you could certainly be having the problem that I was. After you get stuck a few more times, if you can't fix it, then do as I did and measure the cranking resistance, buy or make your own resistor of matching ohms and solder in place.
http://www.e-z.net/~iei/vatts.htm
There's a page with instructions. Go to the bottom and use Method A. Hope this helps.
You would need to remove the dash panel below the steering wheel and then carefully access the wiring harness under the steering column. The job is not very hard, so long as you are somewhat adept at repairs. You need an ohm meter and soldering gun. Once you measure cranking resistance, you can go to Radio Shack and buy a resistor that closely matches. If they can't get with 5%, then you may need to make one. The Radio Shack folks can tell you how to come up with the proper resistor. I would estimate total time for this repair at about an hour. Cost of resistor(s) will be only a few dollars.
Of course, this will permanently dis-able the resistor wire anti-theft feature, but if a crook wants your truck, he'll take it.
Good luck
Old 02-24-2005, 01:27 PM
lloydjv lloydjv is offline
Originally Posted by nadamechanic
Good Morning!
Possibilities???
Thanks!
You may be having the dreaded CTS disease as well. Your truck and most every vehicle made since the mid 1980's has been equipped with a coolant temperature sensor. The function of this sensor is to tell the ECM(computer) how much fuel and air mixture to advance based upon engine temperature readings. The ECM in turn increases the a/f mixture to satisfy the demands of the engine load, temps, etc.
I know it sounds silly to many people that a cheap little sensor can cause so many problems, but in cold start issues or stalling/stumbling issues, I have found that 4 out of 5 times this is the case. For $6 or $7 dollars you can't go wrong if you don't have access to the DTC's or someone who can obtain them for you.
The coolant temperature sensor is located very near or in the thermostat housing and is usually just a single wire, or 2 wire component. At any rate, if the Check Engine light has been on, make sure to reset the ECM after installing any new information sensors.
Good luck and please post your results.
Old 02-24-2005, 01:35 PM
Chevy-SS's Avatar
I forgot to say that my "check engine" light was NOT on. Typically, if it's a sensor, such as suggested in the post after mine, then the "check engine" light would come on and you could read the codes to find out what's wrong.
I was, however, having the "security" light coming on and off at various times. My '98 Silverado truck has been 100% perfect since I did the resistotr wire by-pass.
Old 02-24-2005, 02:47 PM
Re: Re: 98 Silverado Starting Problem THATS IT!
Thanks so Much to both of you for your help! But Chevy-SS, I believe you have the answer! My security light just started coming on and off recently...about the same time that this starting problem cropped up. I am an electronics tech by trade and work for a company that sells resistors so I'm going to give this a try this weekend!
Again, thank you so very much for the assistance and also to automotive forums for presenting a forum to speak to folks like you.
Old 08-30-2012, 03:26 PM
Chev. Silverado Chev. Silverado is offline
GM posted a service bulletin in 2001, which informs the GM dealerships of the problem with the Pass Lock key. It was Service Bulletin no; 01-08-56-004A dated Sep. 2001. This bulletin warns service shops of the problem they were having with this system (Pass lock key). Very few dealerships corrected the problem.
My concern is, if this is a problem we bought the vehicle with why do we have to pay for the repairs? Maybe we need to start a class action against GM, that might get the ball rolling and have our vehicles repaired at their cost
Old 08-30-2012, 03:50 PM
Chevy-SS's Avatar
Wow, this thread is seven years old, LOL.
Anyway, to answer your concerns, it's very easy to do the resistor bypass. And it only costs a couple of dollars. So, if you're having a problem, then it's time for a bypass!!
Good luck......
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
The Following User Says Thank You to Chevy-SS For This Useful Post:
Chev. Silverado (08-30-2012)
Old 08-30-2012, 04:02 PM
This may be 7 years old but the fact of the matter is that we are all having the same problem, my P/U is back in the repair shop for the same reason again. and every time it goes in there is over $700.00 in repairs all for the same thing.
I have asked about a way to disable this system or bypass, but no mechanic haas been able to tell me how or were to take it to do it.(I;m not a mechanic or a Tech)
Old 08-30-2012, 07:56 PM
j cAT j cAT is offline
if you bring your vehicle to an auto alarm shop they should be able to completely remove the security system.
700.oo for what work ? what parts ? did you get the detailed info BILL or just thats $700 ? mechanics are good with bolts. with wires not so much .
Old 08-31-2012, 08:51 AM
Chevy-SS's Avatar
Oh man, I feel your pain. I checked the links from my old posts and see that they no longer work, which is unfortunate, as they had some great diagrams and instructions.
As I have said numerous times in this thread, the 'resistor bypass' is something you could (and should) do yourself.
I will search and see if I have a copy of the instructions saved somewhere. If so, I will upload to my server space and post a link to make it available for download.
Dave in RI
1968 427 Camaro SS
2004 Corvette Coupe
Old 08-31-2012, 09:17 AM
Chevy-SS's Avatar
OK, I found the old diagram that I worked from. Here is the permanent bypass procedure on the security wire.
Try this when truck goes into "tamper mode". It will start then immediately die. Wait five or ten minutes, and then it will start right up. Of course, confirm that your vehicle has appropriate Passlock as noted in posts above before doing this!!!
Here's a diagram showing what I did. You need to take off the lower dash panel to get at the wires.
I cut the yellow wire, then measured the cranking ohms resistance at 577. Then off to Radio Shack, where they had 560 ohm resistors +/- 5%. I bought a pack of five for 99 cents. I measured the resistors to find the best one. Closest I could get (to 577) was 554 ohms, so I soldered that one onto the yellow wire (processer end) and into the orange/black wire.
The full instructions said I needed to be within 1% to 2% on the ohms. I was more like 4% off the 577 ohms, but the truck fired right up with no problem.
That was over 8 years ago and the truck has worked perfectly ever since I soldered in the resistor. I fixed the problem for about two dollars in parts!
Let me know if this helps at all.................
Dave in RI
1968 427 Camaro SS
2004 Corvette Coupe
Old 08-31-2012, 09:38 AM
again bring to an alarm / remote start installation shop. they will install what was just posted. this is not expensive . [delete security system]
replacing the security parts to make this work as built does cost $700-1000 because of GM jacking up the cost of parts they know are defective.
I would not attempt this with your abilities .
The Following User Says Thank You to j cAT For This Useful Post:
Chev. Silverado (08-31-2012)
Old 08-31-2012, 11:55 AM
Thanks a lot. As soon as my p/u comes out of the repair shop I will take it to the alarm place.
The parts they charged me for was "Pass lock key, to re-set the key and 4 hours of work" Now they are telling me that there is a Module that needs to be changed, but they don't have it in stock therefore I have to wait 7 to 10 days for it to arrive. This is a pain in the you know what.
The problem is that I llove the way (when it is working) this p/u performs on the road and the farm. Again thank you
Old 09-01-2012, 09:30 AM
gremlin96 gremlin96 is offline
get all of your paper work handy, then call Chevy. be nice and ask them how many times does it take be for they will do the repair for free or do a permanent fix. replaceing the same electroinc parts over and over is not fixing the problem.
Old 09-01-2012, 04:54 PM
good.
the bypass is the perminent way to go. those modules are defective crap,also a rip off !
