Old 02-24-2005, 11:13 AM
cnilkyrclit cnilkyrclit is offline
No Heat
Hello All, My Sister In Law Has A 96 Tauras. Its Not Getting Any Heat. It Has A New Thermostat, And A New Water Pump. What Else Is There That I Can Do To Try And Figure Out What The Prob Is?? Thanx.
Old 02-24-2005, 11:20 AM
sfontain sfontain is offline
Re: No Heat
What's the mileage?
When was the last coolant flush?
Did the heat disappear gradually or suddenly?
Old 02-24-2005, 01:30 PM
Psychopete Psychopete is offline
Re: Re: No Heat
Originally Posted by sfontain
What's the mileage?
To add to this:
What does the temperature gauge read?
Pete
Old 02-24-2005, 04:02 PM
Re: No Heat
96 Tauras, I Believe It Has Roughly 128000 Miles. The Coolant Was Flushed When The New Water Pump Was Put On. Not Sure What The Temp Gauge Reads. This Is My Sister In Laws Car. She Does Drive It Quite Often Though. The Car Did Sit For About A Month When The Water Pump Went Bad. Heat Was Working Well Before That.
Old 02-25-2005, 07:38 AM
Re: Re: No Heat
Sounds like the heater core is clogged. I would attempt to back flush the heater core only. Depends on what the temperature gauge is reading though.
Old 02-25-2005, 07:50 AM
NakedDancer NakedDancer is offline
Re: No Heat
Are you getting pressure on the hose after it warms up? If not then that new Thermostat still could be bad or installed wrong. Like the other guys says, check the heater core as well.
Old 02-25-2005, 08:10 PM
KimMG KimMG is offline
AF - Advisor
Re: No Heat
Feel the heater core hoses and see if they are getting hot after the car warms up. If only one of them is hot, then the core is clogged. Also on most of these cars need the core flushed separately from the rest of the system.
