Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-24-2005, 10:54 AM
nonnaca nonnaca is offline
Engine Stall
1997 honda civic with the check engine light on. The only issue I've noticed since the light came on is that the engine will sometimes stall when the ac is on.
Suggestions before I pony up for the code check, etc?
Old 02-24-2005, 11:36 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Engine Stall
stalls in acceleration or idle? the code is your key.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-24-2005, 11:53 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Engine Stall
if it stalls when the AC is on there is a possibility that your alt is going bad. The load the AC puts on the alt may be too much for it too handle. But then again alt trouble doesn't usually set off your CEL.
Empty Pockets Racing Member #1
Old 02-24-2005, 12:23 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: Engine Stall
The alt not putting out enough volts will cause the battery light to come on, so I don't think that would be the cause of the CEL like you said.
Pull the code that will help very, very much.
