Old 02-24-2005, 04:29 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Wiring Help
Ok I have two 300rms subs (4ohm)(SVC) and i want to hook it up to a 1 ohm stable mono amp 400rms.
I now that the 2 in parallel create 2 ohms. 2 in series create 8. Which is the best way to go, and how many more subs of the same kind can i hook up to this amp before its to much.
And if anyone asks i have/
2 MTX 15's
1 MAAUDIO AMP with digital read
Old 02-24-2005, 08:09 AM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Re: Only The Best Please Help
You'll be able to hook up a total of 4 4Ohm subs to get to 1 Ohm, but the amount of power the subs can take will be reduced somewhat. You generally want to have the lower resistance value, and I think just those two will give you plenty of bump.
Remember: Power = Voltage x Amperage, and Voltage = Amperage x Resistance. (P = V^2 / R or I^2 x R)
Old 02-24-2005, 11:09 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
I'd go with more power if you wanna get four subs. You would only get 100 a piece and that's not enough to get those subs potential. Also note that MA Audio tends to rate at INSANELY high voltages so you probably won't even get 00rms from it.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-24-2005, 12:31 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Re: Only The Best Please Help
Only their "Hard Kore" series are rated like that.
I'd suggest to keep your current subs...and get a 600wrms @2ohm amp!
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
