Hello everyone,
my ponitac bonneville 1990 back fires!...i have no idea why is tht... wht are the possible reasons? below is the car detail: VIN: 1G2HZ51C1L1238845 Year/Make/Model: 1990 PONTIAC BONNEVILLE SE Body Style: Sedan 4 DR Engine Type: 3.8L V6 SEFI Manufactured In: UNITED STATES any help will be greatly appreciated thanks, twins |
Re: 1990 Pontiac Bonneville back fires!!
If it backfires when you suddenly depress the throttle for acceleration, then this means a lean mixture condition and it traces most probably to throttle position sensor (TPS) whose purpose is exactly what the old acceleration pump was for on carburators. For steady condition, the Mass Air FLow sensor is used for proper metering.
Was this car OBD equipped in '90? ANyway, a good description of TPS flaws can be read here: www.avigex.ca/xport/dtc21.jpg www.avigex.ca/xport/dtc22.jpg If backfires happen in condition other that one described above, then give more details...a burnt exhaust valve would also cause this at any speed and condition, but personnally I have not seen that in decades. It could be low fuel pressure, but that is easily tested and do test pressure first before any intrusion in fuel pump cause it is blamed much too often, too easy a culprit .
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Re: Re: 1990 Pontiac Bonneville back fires!!
thanx a tonne for ur reply!!...i m not sure if the car is OBD compliant but i will check n get back to u...i did not get a chance to look at it today (friday)...hopefully tomorrow (saturday) i will have more details abt the car and its problem
thanks once again! |
Is the check engine light on? If so it would be adviseable to get the codes checked..
Yes the car is OBD 1 compliant.. A good thing would be to hook a scantool to the car and see what the TPS is doing... Does this car backfire when you drive it? Miss or stumble maybe even stall out? Does the car start right away? Has this been an issue for any length of time or was it a sudden problem? And how many miles do you have on the car? |
I have a 90 lesabre doing same thing. Did you fix this car? with what?
1967 cougar 390 FE in progress 1993 F350 Crew Cab 5.8 111K 1983 Coachman 23ft class C 460 1988 Bronco 351 C6 1964 Galaxie 428 4sp project 1995 Mustang 3.8 Auto 1966 Mustang Fast back Project 1994 Tracer Trio 1.9 1968 F250 Camper Special 390 |
