Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 02-24-2005, 02:12 AM
Theos Theos is offline
Send a message via AIM to Theos
b18c1 vs h22a Choose??
I'm deciding on what engine to swap out for my 97 civic coupe. I know the b18c1 which is from a typeR integra puts out 210hp, but so does the h22a. I know any B series engine is more easily moddified and tuned, but the h22a is a "beefier" engine. Which would you get if you were in my spot? Thanks.
http://www.cardomain.com/member_page...page_id=630838
Old 02-24-2005, 12:29 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: b18c1 vs h22a Choose??
search.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-24-2005, 12:45 PM
blacksol28 blacksol28 is offline
Send a message via AIM to blacksol28
The b18c1 is the GSR motor, the ITR motor is the b18c5. And to answer your question it depends on what your plans are if your going turbo id go b series.A h22 in a civic is a tight fit to begin with its tricky trying to shoehorn a turbo in there too. It can be done though my friend had a h22 turbo in his 93 hatch for 2 minutes before his motor went. But if you are not looking to go past the motor swap the h22 is cheaper.
Old 02-24-2005, 01:22 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
The h22a engine may be cheaper, but you'll still spend just as much as the ITR (maybe a little more) because of all the parts you need to buy to get it in.
Old 02-24-2005, 11:34 PM
That is a good point. There are many things to consider before you do a swap. Do your research so you get what you want and dont F it up.
Old 04-12-2005, 06:25 PM
civickirb civickirb is offline
i went with h22a in my civic its not that hard... well its tough but it just takes time...i love my h22a pulls hard..i raced a b18c5 and walked about 3 1/2 cars so ur choice.. o yeah vtec in a h22a man my dynos show a 24 horse gain when i hit vtec....
Old 04-15-2005, 10:27 AM
BlazeD0ut06's Avatar
BlazeD0ut06 BlazeD0ut06 is offline
to turbo or not to turbo is the question...
there r people riding with h22turbo but i think it will be heavier onthe pocket as opposed to turboing a gsr..
some people might bring int he weight factor of h22 over b18c1..but it really isn;t that much heavier...
in short if u wanna do str8 runs or on the highway,,h22 is good...
but for those and everything else i would go with b18c1...
search is ur friend as u dunno what motor comes in what car...
Old 04-15-2005, 02:37 PM
V T E C H's Avatar
V T E C H V T E C H is offline
I would go b18c5 but thats just me. And as for HP, i belive that the b18c5 has 195 as does the Prelude, i could be mistaken.
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 04-19-2005, 01:31 PM
projectgsr's Avatar
projectgsr projectgsr is offline
The JDM versions of both motors have more than 195 hp. I'm trying to decide myself which one I want to put in my GSR 2dr. I'll probably just stick to a B series to eliminate the headache of having to modify my engine bay. But I will give the H22 credit.
JDM B18C, LSD tranny, Exedy flywheel/clutch, AEM intake, Greddy cat back, stainless header, Skunk2 manifold, Koyo radiator, Tokico Illumina full coilovers, black 17" Konig Hurry's, dc strut bars, custom cf hood, poly motor mounts, alum. battery bracket, b&m short shifter, Viper alarm, spoon chip, Tenzo R seats, Kenwood amp, Pioneer and MTX speakers w/cross over's, euro antenna, NGK wire's and plugs, Mobil 1 syn. and a whole lot of attitude.
9.4 sec 1/8 mile at Irwindale 4/20/06
Old 05-18-2005, 01:50 PM
SOHCivic SOHCivic is offline
depends if u plan on turbocharging your engine...go with the b18c1 because it has a better compression ratio. if you want the naturally aspirated way go with the H22a4...thats my opinion.
Old 05-18-2005, 01:55 PM
CivicSpoon's Avatar
There is no Spoon
No it doesn't. The JDM B18c and JDM H22a both have a 10.6:1 compression ratio, the USDM B18c1 has 10.1:1 and the USDM H22a has 10:1.
Old 05-18-2005, 05:31 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Actually the JDM H22 has 200hp. I don't know the specs, but I'd imagine the H22 has more torque than the b series engine, and torque is always nice to have. Like others have said, it really depends on your future plans for the car, as well as what you want to do with the car (drag, road race, auto x, etc.)
Old 05-18-2005, 05:44 PM
GudeCiv's Avatar
GudeCiv GudeCiv is offline
Send a message via AIM to GudeCiv
the h22 is probably not worth the money, althou i considered it myself, and i hesitate to say that b/c i almost did it ... the jdm b18c itr motor has 200 hp (worth the money, it pulls madly, i personally kno) , the usdm itr has 185-195 hp..but dont turbo the jdm itr unless u get new pistons, the compression is too high; which is most likely tru of the usdm itr motor as well. but, once you do anything to the itr motor, its value will drop. the usdm gsr motor has 170-185; its jdm counterpart has roughly 185. a gsr would be fun to trubo. if u want turbo, u can run 10's w/a b16 thts turbo'd... and built fer turbo; or i'd consider goin w/a b20 (or dif. spin on tht ls vtec) fer turbo. if u want all motor: u can try the h22. but i'd go w/tha jdm b18c gsr motor unless ur looking to put big bucks into the jdm itr motor (which is already "race built" from factory) good luck motor shoppin
- HONDA THE POWER OF DREAMS -
MY RETIRED MOTOR WILL ALWAYS BE REMEMBERED
SOHC non-Vtec 1.6L 170hp (flywheel)
redline: 8,100rpm ---->
-Gude Race D16Y7 Head
-JDM ZC Block
-Individual Throttle Bodies
Old 05-18-2005, 05:46 PM
95whitehb 95whitehb is offline
Send a message via AIM to 95whitehb
that was from me sorry fer tha diff. name ^^^^ someone else was using my comp. and never signed off!
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap.
'95 CX hatch:
-JDM ITR swap ('98 spec.)
-ITB's
Old 05-18-2005, 11:31 PM
GudeCiv's Avatar
Re: Re: b18c1 vs h22a Choose??
That's right, I'm sorry I didnt sign off your comp laura. That is one hell of a response to his quesitons, and I second everyhting she said. She does know personally since we swapped it in her EG about 2 weeks ago. The ITR is expensive, but well worth the money many fold, if you are unhappy wiht your results, it is a simple swap out even wiht one person and a couple of hours. Also, you can sell the thing for as much as you spent on it to another person wanting an engine with such status. The H22 does have its torque, but its a headache i presume, and its worth crap if you are unhappy with it. Also the H22 has much less available parts, esp variety. So even a b18c form the SIR-G integra would be a great desision and a lot less hurtful in the pocket book.
-JDM ZC Block
