Went to the track my first time in my life, with 240sx
Just got home from the track.
Got 16.2 my best time. Remember its not SE so it doesnt have LSD i just converted it to SE model with SE wheels and all that stuff. my 60 foot best was 2.3 not sure how good or bad that is, never been to the track before 85.7mph was my top speed with best reaction time of .113 not bad for a noobie i say ![]() but the way i see it is, an SE with LSD runs 16.5 , i dont have LSD but i have some mods and i got 16.2 so i was thinking if i get LSD i can possibly get to 15.5 once i get the take off down. because i couldnt launch higher than 2,000k before it would keep spinning my right tire. with LSd im sure ill be able to launch at higher RPMs without any probs, and beat my time for sure. |
Re: Went to the track my first time in my life, with 240sx
sounds like a plan...if your running a 15's time with a baically stock car...your actually doing pretty good...all you have is an exhaust system right? well anywho...yea the lsd with def help your time alot...good job...thanks for posting your time :d
Current cars: 83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5 |
well you can see my mods at the bottom under the supra pic. exhaust, header, intake, clutch... nothing major like cams and cam gear etc..
what kind of rubber do you have?
http://www.cardomain.com/id/dbo240 ![]() ***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE*** |
Kuhmo 711 225s around..
yea basically stock and pretty good for no LSD, your 60 would benefit the most from an LSD
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines |
Not bad. I'd say pretty good reaction times for a first timer. 60' is pretty good too.
My best was a 15.8 with K&N cone filter, header, exhaust, and toyo FZ-4 205s. What RPM were you shifting at?
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
Re: Re: Went to the track my first time in my life, with 240sx
you got 15.8 with your 92 SE wich is LSD right? and i launched at about 1500-2000 rpms redlined first shifted, redlined seconds shifted and passed the line on my 3rd gear hitting redline as well |
I think in higher gears it's better to shift a litle after 5500 cause that's where the power starts to drop off, but I could be wrong.
yeah you should short shift the ka as soon as you feel the car stop pulling. i can still feel it stop pulling even with the turbo on making power straight to redline. the power hit hard, then it tapers off slow, so i usually just short shift it.
303whp stock internal KA-T 94 Acura NSX Best E.T. 13.559 Best Trap speed 107.62 mph |
Re: Re: Re: Went to the track my first time in my life, with 240sx
Not all SEs come with open differential. It was all LEs because of HICAS.
so redline first gear and then probably shift my second at about 5500 or so and my 3rd at 5500?
Something like that, you can probably go to 6000 in 2nd or even redline, but I'm not sure, I'm going by what I do in my dad's Altima. Go by feel, you'll see.
Do 92 SE coupes come with LSD?
![]() Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows |
