Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 02-24-2005, 12:16 AM
attackdog attackdog is offline
Battery drain problem???
Hello Everyone. I have a 2001 Yukon and replaced the battery about 3 months ago. If my truck sits for more than a day, the battery will be totally dead. I have checked pretty much everything that is aftermarket to make sure it is off when the key is off. I took the battery back 2wice and they said the battery is good and my charging system is also good. Any suggestions on how to troubleshoot this problem would be appreciated. Thanks.
Old 02-24-2005, 08:53 AM
grampa bob grampa bob is offline
Re: Battery drain problem???
Some help to get you in the ballpark:
If you have a ampmeter connect it in series with the battery & ck for current flow, then pull fuses one by one to isolate which circuit is causing the current drain.
Old 02-24-2005, 11:10 AM
Denalix5 Denalix5 is offline
Check the alternator. Sometimes it doesn't recharge the battery so the battery is depleted when driving and then when you park it and then want to restart it, it doesn't have enough juice to start.
Old 02-24-2005, 03:01 PM
I had the alternater checked and it was fine. It showed that it was charging at 14.6 volts. This one is a stumper for me. Thanks again.
Old 02-24-2005, 04:00 PM
myhd myhd is offline
Have you checked to see if the dome lights are coming back on?
My yukon did this, sometimes hours later. Turned out to be defective dome light switch.
As a matter of fact, mine went dead last week after being OK for about 1 month. I kept watching it and the dome lights came on a while after I shut it off.
Old 02-25-2005, 05:37 PM
Thanks for the reply myhd. Is there a way to test the switch to see if it is bad or not? Thanks again.
Old 02-25-2005, 05:46 PM
Stryder Stryder is offline
its a relay switch something is stuck on...ur fuel pump...could be anything listen for sounds when ur car is off...Something is def stuck on like a relay...check ur fuel pump thats a number one problem
Old 02-25-2005, 07:30 PM
Stryder. is the fuel pump relay under the hood or on the frame? Thanks.
Old 02-26-2005, 06:13 AM
Hi all. I kept checking on the truck overnight and it is not the dome lights. It is cold here in Ohio, and I noticed the frost on the windshield was melted over the defrost areas. Could this be the problem? If so where do I start looking? Thanks again.
Old 02-27-2005, 10:43 PM
MaxUT34 MaxUT34 is offline
hey, my yukon did the same thing for the longest time. I had a alram instaled profesionaly and i assumed that was the problem so i took it back to them. They said that the reason it was draining was because the light under the hood that you turn on and off manualy was left on. after that it hasnt happend again so my advice to you is check that.
Old 03-03-2005, 01:08 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
I had a problem with my original keyless entry module turning on my dome light in the middle of the night. A relay stuck or something. I removed it and replaced its functions with an aftermarket alarm. No more Middle-Of-The-Night-Dome-Light.
Old 03-03-2005, 06:35 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: Battery drain problem???
Check the battery cables. There was a silent recall on them because the AC Crapo batteries would leak acid down inside them and rot them from the inside out.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
