Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-24-2005, 12:07 AM
uummm's Avatar
uummm uummm is offline
Send a message via Yahoo to uummm
head problems
i have a 90 olds cutlass supreme, my bro did a burn out and let it ping off the rev limiter when it was 7000 miles overdue for an oil change, it devoloped a knocking sound in the top end that sounded like a belt hitting something metal and he had a total loss of power. the motor is a high output quad 4 with about 80000 miles, i think the head gasket may be bad, ive got the cams and lifters off, but i think some of the lifters may be sticking as well. i would appreciate any input that may help me pinpoint the problem so when i get it back together the problem isnt still there. thanks for any input.
Old 03-02-2005, 06:28 AM
computerdude14 computerdude14 is offline
Re: head problems
are you sure that the knocking sound is in the top end, and not in the bottem end? ive talked to a friend of mine and he said that usually an actual "knocking" sound is due to a connecting rod knocking against a rod bearing. I also unfortunately have had a bad experience with a rod knocking, but it was in my 91 honda prelude si. heh, in fact i figured it'd blow up due to it throwing the rod eventually, but instead it managed to blow its rear main seal but i was lucky enuf to be turning into my driveway be4 it actually started spitting out tons of oil so i dont think she is damaged too badly. however, if your sure that the "knocking sound" is comming from the top end, then it might be a rocker arm or pushrod or something like that. when you say its a knocking sound, do you mean that it sorta sounds like a little hammer inside the motor, or more like a "tapping" or "ticking" sound? maybe id be able to help you a little better if you could possibly describe the sound a little more specificly? heh, at any rate i wish you the best of luck!
mike
Old 03-02-2005, 01:10 PM
uummm's Avatar
Re: head problems
well, the tapping kinda sounds like a belt hitting sheet metal, and it is coming from the top end, i thought it may be a bent valve, but none look bent, possibly sticking though, i havent had the head off yet to check them. but the knocking is definately not coming from the bottom end, sounds like the cam area. i just wanted to know what i should replace to prevent it tapping when we put it back together. thanks for the info though.
Ryan
Old 03-02-2005, 08:13 PM
Re: Re: head problems
Ryan
well when you put it back together, make sure you set the valve clearance properly, i dont know exactly what the numbers are for that stuff off the top of my head but a handy hanes manual should tell you all that good stuff. also make sure all the bolts/nuts that hold the rocker arms down are tightened according to specifications. from what you told me, i think it might be just a case of a valve or two having too much clearance between the rocker arm and the valve stem. that would also create a similar noise that would sound like what u described. if you are also removing the valves and springs and whatnot, it wouldnt be such a bad idea to put sum valve lube on em, but remember, dont try to glob it on the valve stems, just barely a thin coat enuf to see that its on there, cuz any excess that it scrapes off while moving up and down will just pile up. good luck and if u have nemore ?'s just ask.
mike
Old 03-02-2005, 09:22 PM
uummm's Avatar
Re: head problems
i dont mean to be a dick, but its a dual overhead cam, its a quad four. therefore it has no rocker arms, just cams to lifters to valves. any suggestions from that info would be greately appreciated.
Old 03-03-2005, 05:33 AM
oh i apologize... i completely forgot that they are OHC or DOHC whatever u wanna call it lol. i guess the noise would have been from the lifters... possibly anyway. again, make sure u set the valve lash/clearance according to specifications... cuz an excessive gap would cause that ticking noise. hope this helps,and if u want more info lemme know and ill see if i cant dig up sumthin 4 ya.
mike
