Old 02-23-2005, 11:27 PM
camaroguy04 camaroguy04 is offline
Question engine swap
what all do i need to know about changing my v6 (3.4) to a custom builtv383 stroker! I really need to know, i am doing this in 3-4 months. any info is greatly welcomed.
Old 02-24-2005, 12:39 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: engine swap
do a search on the forum, there are many threads that cover this topic, and its 1:40 in the morning here, so im not gonna launch into a full explenation. someone you might want to contact is
www.fbodymotorsports.com
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-25-2005, 12:25 AM
Re: engine swap
everyone says search, i did find anything that is why i am asking. I NEED LINKS OR SOMEONE TO TELL ME WHAT TO EXPECT
Old 02-25-2005, 12:11 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: engine swap
You need a donor car cause you need basically everything from the V8 model.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-25-2005, 03:26 PM
Re: engine swap
this summer i am putting my custom built 383 stroker engine into my 95 camaro, what all do i need to upgrade. i am upgrading the rear end to 3.73 gears with limited slip diff, and c-clip elimantors a rear end suspenstion kit. i am also putting new shocks and springs on the car (v8 shock and springs) i have gotten new motor mounts, sub frame connectors and a strut tower brace, i have a 5speed in it right now and want to keep the 5spd i new mount will bolt up to it, that i know, i have a centerforce dual friction clutch and throw out bearing, will this hold 450hp for a few months? and what else if anything do i need to do. and plz dont tell me to sell the v6 and get a v8, b/c i am not going to do it, i lvoe my camaro toooooo much. anyone who has done this before or knows anything about it, I NEED YOUR HELP, THANKS
Old 02-27-2005, 12:43 PM
89IROC&RS's Avatar
Re: engine swap
Ok, basicly here is the quick and dirty, in order to swap to the 383, youre gonna need parts from a V8 equipped doner car. now, is your 383 made from an LT1 or a SBC? because that will decide if you can just use a doner car or if youre gonna have to do some fabrication. Also, is your 383 going to be computer controlled or carbed? After we know these bits of info we can help you further.
your drivetrain sounds good, except that the 5 speed, if its the same as the one used in the third gen camaros, will probly eat itself alive behind 450hp.
Old 02-27-2005, 04:05 PM
Re: engine swap
it is a sbc, not lt1 and it will be carbed, and about the tranny, i an looking for a good used one if you know of anyone who doesnt want theres.
Old 02-28-2005, 12:35 AM
89IROC&RS's Avatar
Re: engine swap
ok, heres the rub, while im not entirely sure about this, you may have to modify some engine mounts to put the sbc in the fourth gen camaro. Because you are running a carb, you can just run fuel and spark to the engine and be fine, which will require manufacture of some fuel lines to go to the carb, and the swich from the electronic fuel pump to a mechanical, or lower power in line electronic fuel pump. the factory fuel injection pumps run too much psi for carbs. Youll also have a helluva time trying to figure out how to circumlocute the PCM and still retain propor function of the remaining modules in the car without setting a perminant error code. Youll also have to put together your cooling system from scratch, the radiator will have to be an LT1 fit, but i think the hoses are reversed, so you might have to have the radiator modified to run with a standard cooling system setup. you shouldnt have any problems with exhaust, and your suspension should be fine. its 1:30 so i may have missed a few items, but i think thats a good cover of the situation.
