Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-23-2005, 10:15 PM
Brooklyn Tony Brooklyn Tony is offline
car wanders 1994 g marquis
HI BrOOKLYN TONY HERE,A friend of mine has a 1994 grand marquis with approx 90000mi .HIS problem is at about 40 mi an hour and above the car wanders and is hard to controll. He replaced the pitman arm,I told him to get the alignment checked and maybe the drag link and idle arm may be worn or some other front end part. Is there a common problem withthis y ear , HE had this problem since he bought it in 1997. thanks for any info . the car has allnew tires.
Old 02-24-2005, 02:54 PM
violetaria violetaria is offline
I have a 95 gm and have had problems with the ball joints. This sometimes caused a wobbly ride at higher speeds. You may want to get those checked out (I got mine replaced at Sears for a reasonable price after they snapped). You could also check and make sure the rim isn't bent or something.
Hope this helps
Old 02-24-2005, 09:21 PM
Re: car wanders 1994 g marquis
Thanks for YOUR reply, I will notify my friend.BROOKLYN TONY.
Old 02-25-2005, 08:52 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Tell him to also make sure the hub nuts holding on the rotors are tightened correctly; those could also cause it to wander.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
