Old 02-23-2005, 07:40 PM
GrandPrix1999 GrandPrix1999 is offline
Performance Shift
Iv'e got a 1999 GT and on the instrument cluster I can see the words Perf Shift. I'm pretty sure the car has everything but the supercharger. Does performance shift only come with gtp's? If not what do I have to do to activate it?
Old 02-23-2005, 08:48 PM
v8soldier v8soldier is offline
Send a message via AIM to v8soldier
If it is set up the same way as my 2000 GTP it should have a little button on the side of the shifter you can push to engage/disengage the performance shift.
Old 02-24-2005, 04:08 PM
carnutcass's Avatar
carnutcass carnutcass is offline
I'm pretty sure Performance Shift (PS) was not available on the GT in spite of the fact that Pontiac used the same DIC. To activate PS you'll need a reprogrammed PCM.
Old 02-24-2005, 04:11 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Performance Shift
That's one thing I like about you John. Your never wrong.
Old 02-24-2005, 07:37 PM
carnutcass's Avatar
Tell that to my boss!!!
Old 02-24-2005, 07:55 PM
Your Wife would say the samething. Right?
Old 02-24-2005, 10:11 PM
94sportsedan 94sportsedan is offline
You can make the light on the dash come on if you want. On my 2000Gt it was blue, I just grounded one side of the light bulb, behind the instrument cluster.
Old 02-25-2005, 04:33 PM
Yah I looked I definatly have no button for that. thx for the input.
Old 02-25-2005, 05:29 PM
Re: Re: Performance Shift
If you have the reprogramed PCM you don't need a buttom. You can wire a switch. That what a couple of guys have done.
Wireing the light on? Why? that like putting Hemi tags on a Chevy.
Old 02-25-2005, 05:40 PM
Well at the time I had a dhp pcm which was programmed for performance shift to always be on.
Old 02-25-2005, 06:07 PM
So do I, but I have a switch which turns it on and off. Want to know for sure if it's "on"? Take your car up to about 35-38 MPH and "jump on it". If it jumps into 1st gear, it's on. If it doesn't, wire a off/on switch.
For that, I would get a hold of Cass.
Old 02-25-2005, 08:27 PM
carnutcass's Avatar
If you have a reprogrammed PCM and you want to run Performance Shift always on, You can simply run a jumper wire from pin 21 on the clear connector to ground...............Yay!
Old 02-25-2005, 08:45 PM
You never got the "BOSS" thing did you?
Old 02-25-2005, 10:49 PM
carnutcass's Avatar
Of course I did.
