Old 02-23-2005, 06:37 PM
BlazinUP BlazinUP is offline
how long do the timming chains last..on average?
iv a 93 4.3 vortec.........
i was wondering......about how long the timming chains last?
Old 02-23-2005, 07:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: how long do the timming chains last..on average?
depends on how you drive it. Higher RPMs, low quality oil, late oil changes, etc will shorten it's life. My grandpa's got a Silverado with a 305. The timing chain in that lasted close to 200,000 miles. I have 158,000 miles on my Silverado 350 and the timing is starting to get a little bit sloppy (still runs great). I'll be putting aftermarket gears in it. They are fairly popular for the 350s, and should be the exact same size as the 262. I'd recommend getting a set of gears. They're a bit louder, but last almost forever.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-23-2005, 09:25 PM
OverBoardProject OverBoardProject is offline
Banned
Your right about J-Ri, but you failed to mention that most gear sets are noisy, so most people don't like them (although some people love the noise) If you found a quiet set please let us all know what type that you bought Thanks
Old 02-23-2005, 10:49 PM
gear set? whats that.......and why would you want gears insted of a chain.......?
Old 02-23-2005, 11:06 PM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
?????? well....
Simon R
2001 Silverado W/T 4.3
124,000
Old 02-24-2005, 12:03 AM
Banned
A gear set has 2 big gears which go where the timing gears go on your engine... plus 2 gears held together with something that looks like a big chain link holding them together. This gear piece links the bigger gears together, replacing the timing chain.
This system lasts practically forever, and can never break.
Most racing motors use gears for reliability
Old 02-24-2005, 11:03 PM
oicccccc thnkz
Old 02-25-2005, 08:57 PM
blazee's Avatar
blazee blazee is offline
Problem?
They usually last until they break.
Old 02-25-2005, 08:59 PM
great insite.........how'd you ever come up with that masterfull comment
Old 02-25-2005, 09:05 PM
blazee's Avatar
Problem?
Years of experience.......Professor Blazee, Master of the Obvious
Old 02-27-2005, 04:50 PM
zxkevinxz zxkevinxz is offline
on a similar note - i've been hearing a chatter up there and it's almost like my chain is hitting the cover. possibility? i'm going to tear into it anyway but it would be cool to read something from you guys prior.
1986 CJ-7 Renegade
Old 02-27-2005, 06:37 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
I have seen in Summit,noisy gears and quiet ones.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 02-27-2005, 07:43 PM
Banned
Re: Re: how long do the timming chains last..on average?
good time to change it then. Those covers can't be cheap to replace, plus when the timing chain in some engine's brake the valves hit the pistons causing severe damage.
I'd just stick to a quality timing chain and gears. Replace all the seals that you disturb while your at it.
Old 02-27-2005, 08:29 PM
When I got a cover it cost $40.00.
Click here
My $12.00 Sunfire
