Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 02-23-2005, 03:21 PM
Viala Viala is offline
how many codes
hello
who knows how many codes can be read on the diagnostic plug?
thank's
Paul
Old 02-23-2005, 07:37 PM
LMP's Avatar
LMP LMP is offline
Re: how many codes
It depends: '93 with OBD1: some can blink the light:
www.avigex.ca/xport/codes3800.jpg (all of these I think)
Several others relative to brakes /ABS require the scan tool.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 02-23-2005, 09:01 PM
GregA's Avatar
GregA GregA is offline
Re: Re: how many codes
LMP,
Just wanted to let you know that the link didn't work.
I believe it should be:
www.avigex.ca/xport/3800codes.jpg
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 02-23-2005, 10:48 PM
Re: Re: Re: how many codes
LMP,
what is the meaning for ! OBD 1
Thank you
Paul
Old 02-24-2005, 01:16 AM
GregA's Avatar
Re: Re: Re: Re: how many codes
Originally Posted by Viala
LMP,
Thank you
Paul
Paul,
That is the OLD system for the diagnostic / error code storage / reporting. I believe the switch to OBD-2 (or OBD-II) was somewhere around 1996.
Anyway, the older system used a simple "test plug" that was inserted in the connector and you could then turn the key on and "read" the codes (the check engine light would flash in sequence). At least that's the way it worked on my old car.
The newer system actually has a serial "communications bus" to the vehicle & computer and can monitor a whole bunch of systems in your car. Do a search for "OBD-2" and you will probably find all you need to know about the system.
What model year is your vehicle?
Take Care,
Greg A.
Old 02-24-2005, 07:06 AM
LMP's Avatar
LMP LMP is offline
Re: how many codes
OK Greg you found it the right way...sorry for the inversion, I had not checked out.
Anyway, all that I have scanned from my '93 service manual can be browsed through at
www.avigex.ca/xport
ANd indeed, as Greg explained, OBD stands for On Board Diagnostic. All cars use the 2nd version now, but in '93 , Transport was on the 1st version.
INstructions for getting the codes out :
jump terminals A and B in the diagnostic plug
www.avigex.ca/xport/plug.jpg
TUrn Key on
Read the light codes, the 1st one being 12 (1 blink then 2) to indicate diagnostic mode and then all stored error codes come next.
Old 02-24-2005, 02:01 PM
Re: Re: Re: Re: Re: how many codes
Greg
it's a 3.8 l 1993 and I don't if the codes will give the solution
for the problem Ihave with the injectors and the fuel pump
WhenI put the key on , the pump is make a noise and normally stop , but now it doesn't stop and the injectors are cliking with no stop, of course the engine doesn't start!!!!!!!!!!!!!!!!!!
Good day
Paul
Old 02-24-2005, 02:05 PM
LMP
finally it is like Morse language , so I have to write very fast what I see on the light
I will try
thank's
Paul
Old 02-24-2005, 03:06 PM
LMP's Avatar
LMP LMP is offline
Re: how many codes
I guess at one time the battery was completely disconnected from the system for a little while....whick normally evacuates all previously stored codes.
But after you get some late codes reading, I would in fact totally disconnect the battery, turn the lights on (they wil not light up...) to discharge any residual charge, and then connect the battery back to reinitialise the computer....hoping it might solve the errraic behaviour.
Old 03-03-2005, 02:55 PM
that's it the erratic behavour stopped and the car strat
Thank's
Paul
