| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
V8 swap question
I've got a LWB 1985 S15, it HAD a 2.8 in it and I was wondering what all will I need to do to put a 350 Small Block and a th350 turbo transmission into it. I know radiatior motor mounts and probably an e-fan in it but what do yall think I'll need to change out for it. I have a set of 4.3LV6 mounts, will those work or will I need the mounts from the ambulance the engine is coming out of? What about the crossmember?
ANY help will be appreciated!
I'm back after a long mental evaluation and heavy medication! If you can't be a good example, you can always be a horrible warning! |
Re: V8 swap question
There are engine mount kits for 350 swaps into S10's S15's...it is a very common swap. there are also books on it all over the place... pick you one up and it will tell you EVERYTHING step by step...
v8 fiero
too h e ll with the s10 buy you a 500$ fiero and the conversion kit from v8 archie.
You should check out the Chevy, S10 section of this forum site. There are tons of questions and replys to this very same question.
P.S. - there is quite a bit of work .. more than just replacing a rad and fans. Check it out >>>>
