Old 02-23-2005, 03:32 PM
jjohnson2499 jjohnson2499 is offline
airbag light flashing
I curbshot a corner hard. Now my airbag light flashes once, then 9 times, it repeats this sequence a couple times then stays on. Anyone have an idea what this is??
Old 02-25-2005, 09:13 AM
NakedDancer NakedDancer is offline
Re: airbag light flashing
An air bag is a tricky thing and because it is ment to save your life do not risk trying to shade tree this one, get it to a qualified mechanic. This problem (your life)is always worth the money.
With that said you might try disconnecting the (-) battery cable for a few minutes and see if it resets, but even if it does the bag may not dep[lywork right when you need it.
Old 02-25-2005, 09:18 AM
Just read when you are working around the air bag to disconect both the negative and positive battery cables then wait two minutes for the electronic module backup power supply to be depleted.
I would take it to a mechanic to be on the safe side.
