Go Back   Automotive Forums Car Chat > Buick > Century
Old 02-23-2005, 12:40 PM
the bench man the bench man is offline
service engine soon light (yellow)
this morning upon starting my vehicle this light came on... now what? Is it a simple fix? can any prepare me?
Old 02-23-2005, 01:53 PM
tremblay tremblay is offline
Re: service engine soon light (yellow)
If your engine runs like normal, its nothing to worry about its just some kind of electrical malfunction with these cars, my service engine soon light goes on and off sometimes on my 89 buick century and i have no problems with my car...its nothing i would worry about
Old 02-23-2005, 07:18 PM
NakedDancer NakedDancer is offline
Before I would go right off to ignore mode, check all your fluids, and check the engine codes. If you donn't know how go to a local autozone or simular store and ask for the gm code key and book. They used to give them away for free, not sure now. If all else fails disconnect the negative battery cable for a few minutes to reset the codes and see if it happens again.
Old 02-24-2005, 09:03 AM
thanks
you know silly me.... some one suggested that i check my gas cap first... and ill be darned... it was not on.... I didnt have it turned to click to set it.... after fixing that I drove for 2-3 mins and the light is off.... so thanks to all who responded.... maybe i learned a quick easy lesson
Roy
Old 03-25-2005, 04:37 PM
anamandy anamandy is offline
I had the same trouble with my '96 Century. I was using Citgo gas at the time. When I changed to Mobil gas the problem went away. I think crappy gas will cause the light to go on. Also, I put a bottle of fuel injector fluid in the gas and get much better milage now too.
