Old 02-23-2005, 01:25 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Talking how do i make my head lights brighter?
my head lights suck on my 1992 talon 2.0 NON turbo, wondeirn what i can do to make them brighter? buy clearer lenses? brighter bulb? get those annoying bright benz lights!
Old 02-23-2005, 02:02 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: how do i make my head lights brighter?
i never say this but you should search my man,we have talked about this a thousand times the piaa bulbs and ebay bulbs blah blah blah and the ones on the benz's h.i.d have fun spending that cash ,,byee
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 02-23-2005, 03:39 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
yeah, that is true. just do a search and you will find endless threads about this.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-23-2005, 05:05 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
try getting them aimed first and then see. check for haze on the outercase or fog on the inside. visual inspecition should tell you something is wrong if they are that bad. but i would have them aimed first.
95 Talon TSI AWD
97 Eclipse GST
Old 02-23-2005, 05:42 PM
EDMUND65's Avatar
where do you get head lights aimed?
Old 02-23-2005, 05:57 PM
xzozo xzozo is offline
Your local Mechanic or the dealer can aim your lights. If you were mechanically inclined you could do it yourself.
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
dealership
Something new is coming...
Old 02-23-2005, 09:04 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
you can get a HID kit for about 300 on ebay.
Pictures of the Truck
Old 02-23-2005, 09:08 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
any 300 ebay hid kit is shit. you need the right lens for hids otherwise you are a hazard to other drivers and i hope they go blind and run you over in their hummer.
hid light spreads completly different then a standard halogen bulb. putting hids in a standard housing just makes lots and lots of glare.
i would recommend either the piaa's or silverstars.
first clean your headlights and get them aimed though. also are you sure that they both are working and you havent burnt out a bulb?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-24-2005, 01:11 AM
macder macder is offline
Send a message via MSN to macder
I have the same problem w/ my headlights. Sometimes passengers ask me if my lights are on. The 1g (non-flip up) just have poor lights from the factory IMO.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 02-24-2005, 01:18 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
its not that bad but they are bright though
Old 02-24-2005, 03:27 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
its cause that lexan material they are made of sucks ass, it ages really badly. here is an easy fix man. buy yourself a pair of Sylvania Silverstar bulbs. you can get the pair for around 30 bucks at discount auto parts or walmart. then buy a little bottle of rubbing compound. use a clean cloth and wipe the lense over with the rubbing compound, you'll see right away how it goes from being yellow stained to clear white! try it dude it worked for me every time.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 02-25-2005, 12:45 AM
EDMUND65's Avatar
what kind of rubbing compound am i looking for?
Old 02-25-2005, 02:57 AM
doesn't work I've tried it made by 3m worked for maybe 2 days the armor all wipes worked for about 2 weeks
Old 02-25-2005, 07:54 AM
Re: Re: how do i make my head lights brighter?
It worked for about 8 months when I did it......8 months later....do it again.
I used a liquid squirt bottle of rubbing compound. stay away from the canned stuff or the paste stuff. any squirt bottle rubbing compound should work fine.
